>>>how to remove/change led display<<<
How to remove/change led display ,the one that shows mpg/ gearbox fault,etc. Has went out,this happened when i had a short blown fuse number 4 passenger side panel, after i cleaned the battery points and changed out 3 relays and 2 fuses including #4 this got the car running again, i found that my led readout is not working at all ,is it big job to change this out does this involve dashboard removal? Or just a case of accessing the speedo? .. Thanks to all
It could be a fluke and may be the same reason mine went out.... there is a resistor on the circuit board that is notorious for breaking loose. one of the members here posted a guide on how to fix it. pulling the dash apart wasn't too bad, i think i broke the clips on every vent but the superglue back good as new. anyway im only 18 and i fixed my display in 30 min with no automotive background. I might not be a good example though...everyone says im crazy for working on my jag =)
