How to verify spark AND how to test for fuel?
Old 03-23-2018, 09:21 AM
Received 2,662 Likes on 1,827 Posts
It would prove very helpful if you could provide the vehicle engine size, or add it to your signature line.
The following 2 users liked this post by NBCat:
Don B (03-23-2018), SteveLeighton (03-23-2018)
Old 03-23-2018, 09:54 AM
SteveLeighton's Avatar
I'm not sure of my engine size. All I know is that it's a V8. I suppose it says what size it is somewhere but I don't know where to look.
Old 03-23-2018, 10:10 AM
The 2002 S-Type is usually fitted with the 4.2 litre unit.
SteveLeighton (03-24-2018)
Old 03-23-2018, 10:15 AM
Are there any DTCs (Diagnostic Trouble Codes) stored, if so post them here. You can access them through the OBD port under the fascia/dashboard.
You should also check the fuel pressure, which should be between 3 and 5 bar.
Old 03-23-2018, 12:02 PM
Red face
Isn't the year and model of my jag showing up? Not sure what you mean by 'signature line'. I went into 'User CP' but didn't see a place to add it there. I don't see a 'signature line' anywhere.
Are you talking about putting that information down at the end of every post? I can do that if that's what you mean.
Old 03-23-2018, 12:20 PM
User CP > Edit Signature
Old 03-23-2018, 03:13 PM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
In USA, 2002 V8 is going to be the 4.0 with the chain tensioners etc problems!
  #28
Old 03-23-2018, 03:54 PM
What are the last six digits of the vehicle VIN?
Old 03-24-2018, 12:15 PM
Exclamation
I think I'm at the end of my road with trying to figure out why my car won't start but I do have a couple of questions. It's assumed that I'm not getting fuel because there is no pressure at the schrader valve. I get that part. People have said that you should be able to hear the motor in the fuel pump when you turn the key on. I've never heard it and I can have super hearing when I turn these high tech hearing aids up. Seriously, I'm like Superman with these things.
So...is it possible that I 'pressurized' something like the can the fuel pump is in or the gas tank the first time I turned the key on and I didn't hear it then? How can I know that the pump is even turning on? Does it only make a sound once at first or should it make that sound every time I turn the key on. If it only makes that sound once and pressurizes something, is there a way to make it do it again. Do I really need a second person to put their ear down there and listen.
Now someone posted something about a crankshaft locator or something like that. That and going back in to replace the filters is just about the only thing I haven't done. I think. Is there a way to test that crankshaft locator thing? Would that make it not pump gas? Would clogged filters make it all of a sudden stop starting? Thanks for your help. You guys rock.
LAST SIX DIGITS OF VIN #.. M38 339
  #30
Old 03-24-2018, 12:29 PM
Based on your VIN, JagV8 is correct in saying you have the 4.0 litre engine. My mistake.
You should hear the pump begin to run when the ignition switch is turned to the Run and Start positions. If there is no fuel pressure at the schraeder valve, the pump is not running, or there is a blockage in the line.
If the Crankshaft Position Sensor stops functioning, the car may not start. If the sensor fails, DTC P0335 is set and the MIL goes on. I have seen engines run using the Camshaft Position Sensors, but will idle roughly or stall.
  #31
Old 03-24-2018, 12:31 PM
Since we have now established you have the 4.0 litre engine, have the primary and secondary timing chain guides and tensioners been replaced with the newer version? If the timing chains have skipped position, that may also cause the engine to not start.
  #32
Old 03-24-2018, 01:17 PM
In other words, if I turn the key on to the run position, right before the cranking position, I should be able to go back to the where the pump is behind the passenger seat and hear it running, constantly? There's not some sort of 'on demand' cut off valve or something that makes it only run when gas is needed?
Timing chain guides and tensioners have not been replaced since I got the car 2 years ago. The last owner might have. But still, wouldn't I still be getting fuel up to the schrader valve regardless?
  #33
Old 03-24-2018, 01:42 PM
VortexXL's Avatar
Did you have spark now btw?
if no: change the crank position sensor.
if yes: proceed with fuel system
The cps will not always generate error codes which can lead to a lot of wasted time in diagnosing.
It just takes 15 minutes to swap out the bugger.
I diagnose these problems for a living, have been doing it for 20 years. These symptoms on any 4.0 jag are in 95% the CPS or bore wash (bore wash is caused by a bad cps too)
kr98664 (03-24-2018)
  #34
Old 03-24-2018, 05:50 PM
Received 13,204 Likes on 6,553 Posts
The fuel pump will not run constantly, but it will run for a couple of seconds to prime the system. It can be difficult to hear due to the sound insulation.
  #35
Old 03-24-2018, 11:20 PM
kr98664's Avatar
Received 2,059 Likes on 1,455 Posts
+ 1 on that!
Lisle #20700 is a good tool for checking spark with coil-on-plug ignition:
Lisle Corporation
SteveLeighton (03-26-2018)
  #36
Old 03-24-2018, 11:29 PM
kr98664's Avatar
I've no experience with a bad CPS on my Jaguar, but have run into this on several Fords of the same vintage. Considering Jaguar's corporate ownership at the time, I suspect some of the control logic was very similar.
My hunch is a no-start condition caused by a bad CPS won't generate a fault code because it's not emissions related. The computer is smart enough that it could tell you this, but since that's not how it's programmed, it's not going to do so.
The OBD system used by our code readers and scanners is primarily designed for emissions related faults, so that's all it's going to tell us. A no-start? That's not an emissions problem, so the computer just crosses it arms and makes faces at us. Sometimes it helps to think like a bureaucrat when dealing with computers.
Another hunch is some dealer-level diagnostic equipment could probably tell you more about a no-start, but we mortals are reduced to making educated guesses.
  #37
Old 03-25-2018, 08:30 AM
JagV8's Avatar
I think the tacho reads about 200 as you crank if the CKP is good. Not sure, though.
I thought the problem was fuel, though. The pump runs regardless of cranking (& therefore of CKP pulses).
  #38
Old 03-25-2018, 12:52 PM
VortexXL's Avatar
sorry mate, not true. At cranking the S will show 0 rpm. Older cars did this but the S is already too digital :-)
  #39
Old 03-25-2018, 02:10 PM
JagV8's Avatar
People have reported that it does but if not then use a scope on the signal.
extheaterkid
08-02-2018 10:53 PM
philg64
06-29-2018 05:47 AM
Greencar89
03-13-2018 02:53 PM
JensenHealey
03-01-2018 11:47 AM
Quick Reply: How to verify spark AND how to test for fuel?
