HVAC Issue - 2000 S Type (Driver's Side Vents - Cold & Passenger Vents - Cool)
Old 05-19-2013, 04:10 PM
abonano's Avatar
Received 1,423 Likes on 1,066 Posts
Default HVAC Issue - 2000 S Type (Driver's Side Vents - Cold & Passenger Vents - Cool)
Hi Guys,
I read through the forum but could not come across the issue I am experiencing:
I finally got around to having my AC compressor and dryer replaced. System was properly serviced by professionals - when the A/C is running - the discharge temp on the driver's side is cold (both center and outer vents) - discharge temp on the passenger side center and outer vents is about 10 degrees warmer... (still cool)
One thing I noticed - the external ambient temp sensor works good and is on target sometimes (temp display) and other days - not so. (going to change it)
Cleaned the temp sensor by the ignition switch a while back with MAF cleaner - still looks good and clean.
I'm leaning towards two possibilities:
Evap temp sensor - passenger side
Blend door - passenger side.
Finally, how many evap discharge temp sensors are there for the 2000 MY? three? Where are they located?
Any help would be appreciated - thanks!
Old 05-20-2013, 05:50 AM
thebiglad's Avatar
I would be looking into replacing the electrically controlled valve on the coolant circuit. I believe it is called the DCCV.
I think at year 2000 you will need a 5 pipe unit, the facelift cars use a 3 pipe setup.
Old 07-17-2013, 08:11 PM
abonano's Avatar
Just to update this issue:
1) The DCCV is working properly - this is not causing the air flow/temperature issue I originally described.
2) I had a spare CCM I purchased a while back - I received some sort of CCM - communications error failure (I have the code stored on my device - I will update once I get it from memory) on my scanner with the old CCM when I ran a diagnostic of the climate control system. (along with 2 servo motor circuit fault error codes)
3) After installing the spare CCM - no more CCM failure code - ice cold air was coming out of all dash vents and the air flow was much much stronger.
4) I am now in the process of tracking the servo motor(s) causing the circuit fault error codes. (Check out my other post for details)
MJ'S Jag
11-10-2022 08:14 AM
Xj812
10-26-2015 05:04 AM
Khan
08-30-2015 10:13 AM
nelsonht
08-30-2015 06:01 AM
NinoGrimace
08-26-2015 05:15 AM
Quick Reply: HVAC Issue - 2000 S Type (Driver's Side Vents - Cold & Passenger Vents - Cool)
