I can not open my trunk the battery is dead-help!!!
#43
Received 2,263 Likes
#46
#47
Hehe...eds...didn't read the profile any closer than you did those clockspring instructions, eh? Not only is she a lady not a man....but a very attractive one at that!(as one would normally expect with a Jaaaaa'aag)
Confession: I've seen the title of this post for (seems like) forever and just figured someone else wasn't aware of the hidden keyhole...but when it got up to 3 pages...I had to click in to see what was going on?!? Interesting...my daughter's 03 has that seized drivers' side lock....I cautioned her if she let her FOB batt's die while away at school she'd have to open the boot and crawl thru....
Machi, good to hear you got it sorted. You probably do want to go key-shopping if all you have is the valet...but take a sack of $$ and a chair (you'll want to be sitting down when they tell you what one costs and that you HAVE to buy 2!...but relax..search out some posts by Brutal/Motorcarman...it is possible to get by with only one and a loaner key and a piece of aluminum foil if the price is too shocking...
#48
Hi All,
To my knowledge here in the UK, we do not have the luxury of a valet key. Well my manual gearbox S does not have one anyway.
Just for the sake of keeping things right, every now and then I lubricate the key locks, including the Boot Lock (sorry, Trunk Lock), with a very light grade oil to ensure they stay nice and easy to use. When polishing the car I give the area around the Boot Lock a special clean just to stop the build-up of muck etc., around it.
Regards
Inver.
Regards
Inver.
#49
#50
+1 and also stops the build-up of muck etc., around the 'oles. I did my yearly walk around today and verified that the main key will operate all the locks on mine. The battery in the fob must be 7+ years old- must be due for a change soon.
#51
#53
unlock door through keyhole
I read in a previous post that someone reported that their key didn't seem to go all the way in the keyhole on the door. When I try that with either of my keys, it goes in only about half way and it won't turn. But when I put it in the hole in the boot/trunk, it goes in all the way and it turns. Is my problem with the door just getting the key in far enough? Does your key go all the way into the hole on your door?
#55
Universal Anti-Lockout Kit(tm)
Never be locked out again!
The Universal Anti-Lockout Kit(tm) uses revolutionary patent pending technology to ensure that you will never need to whine about being locked out of your overly optioned vehicle again. The technology comes in Standard and Professional versions suited to every level of expertise. So easy your child can use it ... even if you can't figure it out.
Standard Universal Anti-Lockout Kit(tm) contents:
- custom usage instruction video hosted on YouTube for easy access
- 2 fluid ounce can of WD-40 with straw applicator
- 1 sheet standard paper towel
- 6 inches of silver duct tape
- 1 handy wallet record card
- 7 days free technical support
Professional Universal Anti-Lockout Kit(tm) contents:
- 8 fluid ounce can of WD-40 with straw applicator
- 1 roll deluxe paper towel
- 1 roll of low visibility duct tape
- 1 package wallet record cards
- 1 slide hammer
- 1 slide hammer screw tip
- 1 pad slide hammer damage waiver release forms
- 1 year free priority technical support
Requirements for Usage:
For each vehicle: at least 2 working keys, 1 currently working door lock cylinder, 1 one working trunk lock.
Initial Installation:
1. assemble straw applicator to supplied can of WD-40 as shown in Figures 1 and 2
2. insert tip of applicator in each lock cylinder to be serviced and spray for 2 seconds
3. insert key into lock cylinder, turn back and forth 5 times
4. repeat steps 2 and 3
5. repeat step 4
6. carefully wipe excess lubricant from key and exterior surfaces of lock cylinders
7. locate a convenient, but secure location and tape key to location
8. record location on wallet card using permanent ink
9. stuff wallet card in wallet
Maintenance:
At least once a year, or every time you use the remote fob to regain possession of your primary keys locked in the vehicle, or every time you use the hidden secondary key to regain possession of your primary keys locked in the vehicle, repeat steps 1 through 6 of the initial installation procedure. If the secondary key has been employed, then repeat step 7 as an additional step.
Professional use of the BF Slide Hammer:
Due to security concerns, please contact the 24 hour technical support hotline for detailed instructions on the emergency use of the BFSH. Incorrect use of the BFSH can cause severe damage to your finances.
SPECIAL EXCLUSIVE MEMBER OFFER
All buyers supplying a notarised affidavit that they have not locked their keys in any vehicle, whether owned, rented or borrowed in the immediately preceding 10 years, or in the case of seniors, 5 years, will receive FREE SHIPPING
OFFER ENDS WHEN YOU LEAVE THIS PAGE!
if you have locked yourself out of a qualifying automotive vehicle more than 12 times in the current year, you may be eligible for a government grant to reduce the cost of your purchase
- 1 slide hammer
5. repeat step 4
Maintenance:
#56
That's an excellent deal, Plums.
However for the person who has inadvertently locked their keys, key fob AND anti lockout kit in the boot we again suggest
http://www.google.com/url?sa=t&rct=j...fVWeXwqg6kSn1w
If small children or wives are also locked in the boot this technique should be employed with extreme caution.
#57
#58
I find it unusual that NONE of the locks seem to operate on the poster's car. Strange. We can point fingers of shame and mutter 'how could he let this happen' under our breath, but that doesn't help get the car running again.
I guess at this point it's time to call the auto club and have them open a door with their slim jims. That- or smash a side window.
gcgjohnson (12-05-2012)
#60
