I can not open my trunk the battery is dead-help!!!
#61
#62
#63
I should think it would have to be a terminal that is hot (+Vbatt) with key in "OFF" position. Not sure the Starter would get you there....unless whichever poster we are referring to managed to lock his/her key in the ignition in "On" - not sure this is possible without some effort, though.
#64
Received 6,361 Likes
#65
I tried the WD40 shake rattle and roll. No joy clockwise or anti clockwise. I was often successful with a slim jim when I worked in the car business in the 70s and 80s. We often had customers and salesmen locking keys in the cars, so I became adept out of necessity. I'll get hold of one and see if my skills are still there after 25 years. Failing that, I will look into charging the battery by finding some connections underneath the car.
#66
Received 2,266 Likes
#68
For this application, either way - accessing the starter solenoid or Rick's port...to supply ext. pwr...doesn't look like fun...especially if you can't get the bonnet open (or into the interior to hook a 9V to the power-plug)
#69
I haven't seen a VDP starter so I am not able to argue BUT unswitched battery +ve in a big way has to get to the starter solenoid wherever it is located - and it can't be far from the starter.
I believe all starters since the 1970s use the solenoid to pre-engage the starter pinion rather than the Bendix system so the solenoid has to be located on the starter motor but, being a Jaguar, I stand to be corrected.
#70
#71
It is also true on every Jaguar V8 model.
#72
Unbelievable! I decided that I was going to solve my locked up S Type problem this weekend. I grabbed both key fobs and the valet key and planned to find a place from underneath to charge the battery or slim jim my way into the car. First, I tried the valet key. It worked? I heard the actuators unlocking the door. I put the valet key in the ignition. It started right up. No dead battery. I stuck the key from the key fob into the door hole. It went all the way in and was operational. Apparently my WD40 squirt loosened it up. I don't understand why I could not unlock it before. Both key fobs work. The only thing that doesn't work is the boot opening by the key. I will check the cable, lube it, reattach it or replace it as necessary.
#73
gcgjohnson (12-16-2012)
al_roethlisberger
09-09-2015 09:14 PM
