I have a problem with my S-type 2005g 3.0v light
vlado (01-23-2016)
Check for any codes, although some may be generated by a weak battery (as above). Checking battery condition should be your first step to avoid chasing ghosts.
Cruise control may be a clock spring problem. Check your audio controls on the steering wheel. These too are part of the clock spring (which I just had replaced).
The following 2 users liked this post by Warspite:
Jumpin' Jag Flash (01-23-2016),
vlado (01-23-2016)
I see that you put the car into Engineering Test Mode. So what did you learn? I see a couple of DTCs that I believe are displayed in hex format, so you'll have to convert them to OBDII mode in order to look them up on the chart and determine what they mean. I also see that your battery may be a bit low so as others have said, your battery may be your problem. How old is it?
My 2005 S-Type had an Electric Park Brake failure in April 2015. The problem turned out to be the EPB module. We tried a couple of used EPB modules but they did not fix it. A new EPB module finally fixed it....
Your problem could be the EPB fuses, the module, the motor/actuator, the wiring, or the cables. You're going to have to find an indie shop with the necessary diagnostic equipment. The trusted indie shop I go to has an AutoLogic diagnostics system. Thus far it has always correctly pinpointed the failed components on my particular car that I could not diagnose myself....
Johnken
01-31-2016 01:11 PM
DaveP
01-28-2016 10:29 PM
PopokI09XF
01-20-2016 06:40 AM
