I met with owner of Euro Tek Designs
Today Phil of Euro Tek Designs met with me to test drive my 03 STR. He said with 90k on the odometer she looked beautiful
and performed very nicely. He's owned an 03 and an 05. Euro Tek of Bronxville, NY also tunes the ECU's for other companies, ie. Euro Toys, etc.
For $1200 you recieve an ECU tune (the meat and potatos), an upper pulley, and a K&N filter (he will delete $40 if you already have one). He has associates that will install the pulley for $200. He highly recommends the upgraded manufacturers belt ($70?) and idler pulley ($90?) along with pulley install. He does not recommend a lower temp thermostat, finding it does little if nothing in conjunction with ECU tune, etc. He feels it richens the top end too much. He did say a low temp therm may be valuable in high temperature regions (Texas).
For no additional charge Euro Tek will retune the ECU if future mods are performed and there is a four year warranty.
Phil feels the stock exhaust tubing is adequate to support higher hp mods (up to 475 hp), suggesting freer flowing mufflers (I have Magnaflows) and eliminating the forward resonators this thursday but not the rear. He also feels placing 2 1/2" pipe and an x-pipe reduces back pressure too much, in additon to losing low end trq. from both; causes an intolerable cabin resonance.
I'll likely have Euro Teks Stage 1 performed next month and may install H&R springs.
Riski, I didn't ask him but I'll call him tomorrow for you...but I believe Phil will tune your ECU for less than $1200 ($900?) if I buy his tune. He's nocking off $40 for the K&N air filter that I already have. We hit it off pretty good. After test driving my Jag he gave me a ride in his 550+ hp 2008 BMW M5 (V-10). I had to remind him that I had four children depending on me. He may come to my office for health care too. I'll see if I can arrange something for us.
Transporter, the ECU tune, upper pulley, and K&N air filter are good for approx. 40 hp and 80 lb/ft trq. He'll raise redline a hundred RPM. He admits the stock exhaust (dual 2 1/4") is adequate to 450+ hp with the exception of the stock restrictive mufflers (I put on Magnaflows and will remove the forward resonators). He doesn't recommend an X-pipe or removing "all" the resonators due to loss of back pressure= loss of trq. from our small cube engines, and high cabin resonance frequencies. He also said a lower temp thermostat can cause loss of power in temperate climates (NY), only warranted in hot climate (Texas). He closed by suggesting to remove the actuated lower airbox baffle for crisper throttle response and blow some oil from the K&N air filter as a means to avoid further possibilty of fouling the air flow sensor. The dude is a wealth of technical info. beyond our comprehension. He owned an 03 and 05 STR and knows our cars inside and out. He drives a late model Porsche, M5 (he took me for a near heart attack ride), and a 2010 Camaro SS he took apart for a future blower project. I hope to have the dough next month. I'm going to Jaguar tomorrow for a reflash of TCM and ECU in hopes of ridding a 1st to 2nd short shift by teaching a virgin TCM program a redline shift pattern.
Marc, yes $1400 if pulley install included. He highly recommends the updated belt ($50?) and idler pulley ($90?) to avoid slippage and squeel. I ask him to consider a group rate (reduction) if others here are interested.
Riski, If crank hp is 440 I figure RWHP is approx. 380 hp TRQ @ crank is 488 lb/ft so perhaps RWTRQ is approx. 440 lb/ft.?
Go to Euro Teks web site to see his published dyno numbers.
Riski, I failed to mention Phil said red line issues have been resolved with his tune due to the ECU willing to adjust outside the factory detune. He said Jaguar detunes the STR for reliability and emissions. Plus later model STR were given even more restritive detunes. He felt the 03's ECU's were given more ***** than later models ECU's.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
The way I have interpreted the new measurement is on the conservative side.
We all can make our own decisions on this subject.
Leads to a moot point discussion with no right or wrong answer.
