I need help and no one knows the answer. Do You?
Guest
Posts: n/a
I have a 2000 S type 3.0. I need new headlight assemblies and I recently found some for a great price. They are actually from an S type R so they are Xenons. They fit on S type R models 2000 - 2004. Does anyone know for sure if they will connect to my S type 3.0? I have called Jaguar and they said they don't know. Called a Jaguar mechanic and he said he thinks so. I can not get a straight answer and I dont want to waste my money buying something that will not work with my car. Please answer me if you can or if you know someone who can anwer this questing direct them to my question. I need to know ASAP because I need to buy these things before anyone else does.
[IMG]local://upfiles/5141/46C1602E8A3642D78AD2A14E48E0A367.jpg[/IMG]
[IMG]local://upfiles/5141/3F216A9DDE1C4AA5BDDB4D804A25A9C3.jpg[/IMG]
The difference between them is that the R headlights have projectors. Your Halogens will not fit in the fitting properly. Bodywise the headlights will fit 100%. But your halogens cannot simply be plugged into the unit without you upgrading to the HID system and fitting in your ballast. I was thinking to upgrade my 2001 headlights for newer ones like the 2003 R. BUT I found out I would need to upgrade to Xenonswhich made me change my mind. Also, the headlights come out by way of removing the front bumper. I wish I could give you better news but the process is expensive and troublesome.
I was about to do the upgrade myself. From what I found, if the headlight assemblies come with the ballast and bulbs. then you need to splice the connection to the ballast. The stock halogen connectors will not fit into the ballast. I don't know how to wire these connections, but if you try using the forum search and look up "HID", "retrofit"or "xenon" to see what other people have done. I'm pretty sure there are a few people that were successful with the retrofit.
Btw, why do you need new headlights? Are they actually broken or is the lens worn out and dull? If it is the latter, you can fix it.
ORIGINAL: bcblade
![Name: Picture004-2.jpg
Size: 38.1 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/189619d1501324141-i-need-help-no-one-knows-answer-do-you-picture004-2.jpg)
HID foglights projectors..
![Name: Picture002-1.jpg
Size: 26.7 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/189620d1501324141-i-need-help-no-one-knows-answer-do-you-picture002-1.jpg)
Pic of HID headlights & fogs against the garage door...
![Name: Picture018-1.jpg
Size: 21.0 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/189621d1501324141-i-need-help-no-one-knows-answer-do-you-picture018-1.jpg)
i upgraded my factory headlamps to xenon projector headlamps on my 2001 jaguar s-type. you have to remove the bumper to put them on, which really it's that hard once you do it your first time, then you have to attach the headlights on the car. once you attach the headlamps, you will notice that there is no space between the back of the headlamp and the car. so have your after-market xenon kit ready to go so you can connect everything and put the bulb inside before you attach the bumper back on. once the bumper is back on there is no way you can really work on them because of the lack of space. after attaching the bumper back on you can use the two screws on top of the headlamp to adjust the projector.
i used http://www.xtralights.com/ which are pricey but have lasted a long time. i thought about the buying the cheaper kits on e-bay but decided not to, even though i hear some of those work pretty good. you have to buy D2S bulbs for the projectors. there was some other stuff i did to the headlight but there is some basic information to get you started. it's a decent project to do and takes time and some money but i think my jag looks better with them.
ORIGINAL: jaguar14
Jaguar14 your headlight didn't have oem equipped hid componets? They shoud unless they were pulled...
is your name really jim jones or are you just ballin out in your Jag?![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
as for the headlights, besides the actual lights you need the modules that control the motors as well as the ballast...im pretty sure at least, other then that they should work how $ much for the lights?
Received 2,191 Likes
you can fit later hid stype in, and have to change the wiring(is plug n play with a small wiring change), I use a relay to trigger ground for those I have done in friends cars. as for the leveling forget it, not only do you need the module, but axle height sensors and correct body harness. Most used one are broken inside this is why theyre replaced, you can tell by grabbing the connector for the high beam and watch the whole inned assembly flop around. I usually FIX this by siliconing a small peice of rubber hose between the high beam connector and housing to hold the assembly up and steady. But stypes are where I get all my HID projector assmeblies that I have modded and use in the bumper for fogs on my 05 Frontier, and I just finished swapping out my wifes 96 VDP lights to the later 98 and up clears and fitting the projectors into the back
goges
10-05-2015 04:53 PM
