I want 20"s what size fits?
Old 05-10-2007, 08:06 AM
Default RE: I want 20"s what size fits?
Oh I feel you Biggie. An easy fix though would be to upgrade the brakes a bit. Maybe new rotors and pads. Get some real nice brake fluid like brake glue or something(think thats what it's called) Then you wouldn't have theat issue and you would still look big pimpin. There is always a way around any problem. With a little creativity and a ton of patience you can make anything work.
Old 05-10-2007, 08:58 AM
bigdreams05's Avatar
True ture! I guess I'm just a bit traumatized. I think 18's will do for me!
Old 05-10-2007, 04:04 PM
Yeah I changed my mind too.
I was going to get 19's I will probably be getting 18's with some fatter tires... probably like 255/45/r18 in back and 235/45/r18 in front..
Do you guys thing a +38 offset will do on the 2000 S-type jags??? LMK
Also... my car is lowered... so I don't want any tires less than 45mm in height
LMK
Old 05-10-2007, 05:51 PM
racerx82's Avatar
I just have one thing to say.....BUrp!.......man that beer was good!
Old 05-11-2007, 01:19 AM
255 sounds like a bit much, bit with the right offset and fender roll, it should do. Don't lower the car though, because rubbing would be an issue even with 1 passenger!
Old 05-11-2007, 04:48 AM
momo's Avatar
ORIGINAL: stein36
Well i have an 02 S-Type with the 4.0 and i'm on 20's. I had a small rub problem with the front drivers wheel well rubbing when i was turning and going over bumps.
Can you post a pic of car? I would like to see your wheels. Howmuch did you pay to have yourfenders rolled? What size tires are you running? Thanks
Old 05-11-2007, 10:24 AM
Does anyone know what the proper offset on our s-type's ranges from??? do you guys think I can put on +35??
LMK
Paul
seviz@aol.com
  #28
Old 05-12-2007, 02:34 AM
04Xtype's Avatar
I think on the S you can have a pretty wide tire, cos on the S-type R's they come stock with a 275/45/18s on the rearif i remember correct
Old 05-12-2007, 08:15 AM
Yeah, but the suspension on the STR warrants such a wide tire!
  #30
Old 05-14-2007, 09:33 AM
I've got 245/35r20's and as soon as i figure out how i will put pictures up. As for rolling the fenders you can go to pretty much any body shop and pay about $30 each fender or take a small bat or hammer and role them yourself. Be careful if you do it so the paint wont crack. I messed up one fender doing that.
  #31
Old 06-10-2007, 11:52 PM
rickytmartin's Avatar
Yo! I have a 2000 S type with 20in 225/35,20 tires and I have no problems at all...
aholbro1
08-05-2021 05:02 AM
MrWest
12-01-2015 09:18 PM
smith356
10-07-2015 06:41 PM
Gerard Radimaker
09-13-2015 10:33 AM
Quick Reply: I want 20"s what size fits?
