i930 scanner DTC B1264
Hi, forum readers, I have just received my i930 scantool, tried it on the Jag (2003 model 3ltr Auto petrol) and don't have any pending codes of concern.
Scanning through the menu I did come up with this code:
Foot servo motor circuit failure B1264
I have had an issue with the heating but not serious enough to be a concern. (the weather isn't as cold in the uk as it gets in the USA)
The question is "Does this situation require resolving / can it manifest into some bigger problem and if so how?"
I have looked on the JEPC and cannot pick up the servo motor and there isn't much info in the search section or on google
Any advise appreciated.
cully
ps. only had 20 minutes use with this scanner but it seems to have quite an extensive menu.
cully
Thanks JagV8 I will check code out tomorrow.
I had forgotten about the JTIS which I downloaded some time ago, but haven't had a need to use it.
I have just tried to bring JTIS up to view on the laptop and it is refusing "invalid path" I have recently downloaded windows 10, which shouldn't have any bearing on above problem but something has changed and it was a nightmare getting it downloaded originally.
I will attack it in the morning
Thanks again
Thanks again
Lost JTIS
Hi;
I upgraded my windows from 7 to 10 last July time and having just had a need to check out a Jag code I find that I have lost JTIS from my computer Not sure when this occurred but when I try to bring it up I get "invalid path" box.
JagV8 suspects the upgrade being the reason!
Any thoughts on above from computer literate readers would be welcome as I am lost.
cully
cully
Rocky15
12-22-2015 06:50 AM
