im looking to buy an s type r
Why don't you introduce yourself chap? Otherwise, if you want an already potent 400 bhp STR to go and sound like a mother: Mina Galleries intake ($135) leading to a Caldoofy intake tube ($200), Mina Galleries' 1.5 lb. pulley ($175), Magnaflow's hi-flow cats (2 for $160) and Tru-X center muffler ($90), dumping into stock or aftermarket mufflers (2 for $180). An ETG or Paramount Performance ECU tune ($995) will eliminate flat spots and raise the redline rpm. All should net 60+ bhp.
![Icon Pimp](https://www.jaguarforums.com/forum/images/smilies/icon_pimp.gif)
Why don't you introduce yourself chap? Otherwise, if you want an already potent 400 bhp STR to go and sound like a mother: Mina Galleries intake ($135) leading to a Caldoofy intake tube ($200), Mina Galleries' 1.5 lb. pulley ($175), Magnaflow's hi-flow cats (2 for $160) and Tru-X center muffler ($90), dumping into stock or aftermarket mufflers (2 for $180). An ETG or Paramount Performance ECU tune ($995) will eliminate flat spots and raise the redline rpm. All should net 60+ bhp.![Icon Pimp](https://www.jaguarforums.com/forum/images/smilies/icon_pimp.gif)
Because if it's just "swapping" for instance it should be a fairly cheap install as opposed to running pipe from cats back
Received 2,263 Likes
bfsgross (02-24-2013)
Hey bfgross, what kind of work is involved swapping the center resonator with the tru X? a little welding? and do you need to buy 2.5 pipe to go the rest of the way back or you use the stock pipe all the way to the boxes?
Beardy
09-18-2015 10:00 AM
