IMT O-Ring replacement (short route) w/pics FAQ
#61
Received 6,305 Likes
#63
#64
Hey guys, thanks for the great write-up. I'm pretty sure this part is giving me problems on the LS too. But I've got to ask: why is there oil in this part of the intake? Seems kinda odd to me and the techs at my local Ford shop have no clue. Planning on doing the work myself when I find the time to replace the plugs and coils. I've got a misfire and burning oil smell with no obvious leaks or drips. Hope you all can help.
#65
It is blow by oil that is getting sucked back up into the engine to be burnt again in the cylinders, part of lowering the emissions. Some of the blow by oil doesn't make it back down and "pools" in the lower port of the manifold.
There is an easy way to replace without having to take the intake manifold off, atleast on on Jaguar 3.0s. I don't know about the LS intake.
#66
I remember a posting by a technician on a different forum (Roadfly, I think) a couple of years ago where he stated that the Lincoln LS Duratech engine did not use intake manifold tuners, and therefore could not suffer from the faulty IMT O-ring problem. Don't know how true or false that statement is, but you may want to check with a local Lincoln service manager and see if he can confirm....
#67
Burnt smell after O-ring replacement
#68
Or even the valve cover gaskets dripping oil onto the exhaust manifolds. Could be a combination of both.
Somewhat easy way to DIY. Pull off the belly pan clean (degrease) under and around the oil pan, drive a day or two, lift vehicle and inspect.
#69
I don't think that is accurate. The 3.9L jag engine in the LS definately does not have the IMT valve. However the 3.0 is nearly identical to that in the Jag, intake included. I have seen the photos and looked at my engine and it does appear to have the same parts. It is cheap insurance at the least.
I replaced the o-rings but was still getting a burnt smell. That turned out to be a small crack in the coolant reservoir. The coolant would drip down onto parts of the motor and coolant tubes, which resulted in a burnt smell. It was hard to locate, initially. I replaced the reservoir (part was around $100, but the install was so easy). I am still smelling something getting hot, but I am hoping that it's just some residual coolant that I need to rinse off. Not sure if the LS has the same faulty reservoir, which the Jaguar parts guy said was a chronic issue with the 3.0.
#70
Can you post the misfire codes?
#71
My untrained unprofessional thoughts are that the inner valve cover gasket meaning the spark plug well gasket is leaking in the #5 or #6 cylinder and that is causing the misfires. Its pretty easy to check the #6 cylinder, just remove the plastic cover, unbolt the COP (coil over plug) shine a flashlight down into the plug well. To check #5 cylinder you'll have to pull off the intake manifold.
P2110 Throttle acuator control forced limited rpm
P2107 Throttle acuator control forced limited power
These were the most recent codes pulled
P0420 Catalyst below threshold
P0304 Misfire cyl 4 (is this one driver or passenger side?)
I'm still getting a miss at about 1800 rpm as I accellerate and about 2200 at speed (60mph) when trying to accellerate on the highway. Sometimes the dummy light will blink when it is really giving me problems (indicates current misfire per owner's manual).
If it is a plug well filled with oil would that require replacement of the coils or would it be enough to clean out the well and coil and replace the gasket?
#72
I'd expect cyl 4 to be your driver side.
Is that "dummy" light meaning ..... well, what? Who is the dummy? Just wondering where the terminology comes from!
Flashing means catalyst-damaging misfire. The kind I would want to fix NOW or not drive the car.
Those codes look to be unique to the LS. Interesting.
#73
Agreed get it fixed pronto.
Also you should find a Lincoln Forum, there would be better information on your LS. Unless its like the 2 Cadillac Forums that I belong to. One not much traffic at all, and the other is a bunch of wanna be's either "rollin' on da' 28s" or "floorin' da' bitch".
#74
Thanks for confirming my thoughts. Definitely need to get this stuff fixed before something really bad happens.
I do have a Lincoln forum www.lincolnvscadillac.com There are some great guys over there with vast knowledge about the performance and mechanicals of the LS. You will always have those "rollin on dubs" kind of people too though. I came here because of this thread and my oil leak, someone at LvC pointed me to this post (and I have always had a soft spot for Jags).
The "check engine light" is called a "dummy light" because the warning method is dumb. Here we are in 2011 and the car can't just tell you what is wrong. It still has to be "read" with tools the average man does not have. Sure, some cars can tell you which tire is low on air or when a bulb is out but You get the same indication for a fouled plug, bad O2 sensor, failing coil or when the gas cap is loose on most cars. The light just irritates me.
#75
Thanks for the explanation of the forums.
Heres another link for checking the IMTs, should be kind of close to an LS then:
https://www.jaguarforums.com/forum/s...ad.php?t=49214
#76
The car was designed in around 1996. Expecting better diagnostics in that era is unrealistic. Besides, hardly any owners even look up the details in the car handbook.
Future cars COULD be different, but as owners don't even read the manual I would not have many hopes. The ones who have a clue read up on OBD, as there's plenty of free and good data. That way the owner isn't dumb.
A really great set of tools for OBD costs about $60. Not getting them tends to imply strongly that the owner isn't genuinely bothered about the issue.
#77
#78
Not really. As I said, the person should get on to their government. Or put a bit of effort in to learn.
Any person not bothering to find out information (especially when it's free!) that is of use to that person but instead spouting about it with terms like "dummy" says a lot about that person.
#79
#80
