inertia switch
Try checking for fuel pressure first via obd2 .
Then if no pressure try pressing the inertia swich . And listen for a click .
And recheck the fuel pressure.
Also have a look at the pats light on the dash to see what that is doing .
And check the mechatronics plug on the trans is seated.
Did you by any chance replace the tcm . If so it will need programming before you can start it .
mlstafford (05-13-2018)
o2manyfish
11-11-2016 01:03 PM
