Info for how to replace brake pads?
RE: Info for how to replace brake pads?
ORIGINAL: bigdreams05
The fronts are pretty simple, just push the caliper back in. The rears you have to twist back in. I think that one side is clock-wise, and the other counter clock-wise...however I don't hold me to it. Good luck.
I'm talking about the piston. The front pistons you push back in and the rears you twist back in. The caliper itself is just two bolts, and no breaker bar should be required. Just a socket and wrench.
That's cool,man I wish I could find someone reasonably priced who will install the pads as I have zero tools. Every place either will only install OEM and others only install stuff if you buy it from them...How's the stock jack? Is it a PITA or tolerable for stock?
The front calipers are pressed back into place with something like a c-clamp. The rear calipers require a piston reset tool. looks like a metal cube that is hollow to accept a 3/8" ratchet. There are 2 nipples on the side that rests on the piston and screws back into the caliper housing. As far as a jack - badmojo said it - don't forget to chock the wheels so the car doesn't roll.
Good luck.
Good luck.
Dang, I just spend $80 on parts (sockets, hydro jack, torque wrench, C-clampand breaker bar) and didn't even get the caliper reset tool. Then I found a friend of friend who works at a tire place who will do it in his shop for $60 on the side. Think I'll return all the used parts.
Got them on and man, did the last mechanic do a job on them. We were having difficulty getting a lugs off. We used a torque wrench just to see how tight they were. 100 <click>, 110 <click> 125 <click>. OMFG. The threads on the studs must be stretched and weaking to hell. I'm shocked they didn't snap. Maybe that was only because the wheels are hub centric.Used abreakerbar with a pipe slipped over it to remove it.Caliperswere on super tight as well. BTW, what is the correct lug torque? I used 90ft/lbs.
