Info on performance upgrades
I have a 03 S type R and i am looking at doing some normal bolt on mods to improve its performance. I am looking into doing exhaust, intake, S/C pulley swap ,etc. So what i need is some of you guy's prior experience on this. So what brands /WED SITES to get or stay away from. What mods are good to do ,etc. ANY INFO WOULD BE GREAT!
You pretty much nailed all the mods. Mafiaoso just came out with a new intake that warrants a look at. Exhausts are more of a taste than anything else as they all help develop more horsepower (Mina, Arden, Magnaflow, full custom). Pulleys come in three main varieties, 1.5, 2.5, 3.5 (correspond to boost levels), and most are the same so feel free to go with the cheapeast. Porting the s/c is a hot topic around here so tread lightly.
Stypernva (02-02-2011)
Thanks for the info guys. I really appreciate it.
I will get a base line on the car this weekend on my brothers dyno. I plan on it anyway. I have a small coolant leak that i need to address first. I just want to see if my mod combos are actually making more power when i do them.
by the way what kind of qtr mile times do the type r cars actually turn @ sea level with good air? Thanks again.
Welcome aboard Stypernva. Dragtimes posts a 13.1 1/4 mile for a stock STR with a K&N a/f on a cool night. A full exhaust mod (hi-flow cats, x-pipe, flow through mufflers, etc., 3 lb pulley (16 lbs.), K&N a/f, Mafioso's modded air intake tube, and a low temp thermostat may yield you 50+ hp over stock (est. 450+ h.p.). Add in a s/c port/polish and ya may recieve an additional 15 hp. I'm waiting for the weather to break to yank off the 1.5 pulley and pop on the 3 lb pulley and Mafioso's modded air intake elbow. Hope to dyno-tune her in the spring.
A lot of the cars getting the heavier mods are older, higher mileage, out of warranty and such STRs are inexpensive to pick up. So maybe the typical XKR buyer is more concerned about preserving his investment?
Have no fear my fellow MOD GUYS! I dont get spooked that easy. I always like to mod my cars reguardless. Mine is low low miles clean unit but i will put my spin to it. I will do my reair on the coolant leak this weekend. Looks to be that coolant line under the super charger. Not hard just looks to be time consuming. What is actually released to the public is never what the original engineer wanted any way, right? They always get their ideas watered down by production time! Thanks for the info fella's.
Do you have a good analyst?...does he have experience with XKR guys too?
Yoo guys should check out my thread on adding boost pressure and temp. gauges to your nav. screen if you have not seen it already:
https://www.jaguarforums.com/forum/s...ad.php?t=49241
Jaguar Forums Editor
Jaguar Press release
09-30-2020 06:53 AM
Ipc838
09-13-2015 03:27 PM
scottatl
09-04-2015 08:08 PM
