Inherited NA S type with a bunch of issues
Old 09-11-2015 | 07:11 PM
Toybreaker's Avatar
The engine is not knocking. Didn't think about just plugging in the new one....
Too late, the old one is already in the trash.
Consistent p0327 P1000 after clearing.
I'll finish assembling it and test drive it today and report back.
Old 12-01-2015 | 06:50 PM
Toybreaker's Avatar
Ok lots more issues.... new thread time.
Old 12-04-2015 | 08:32 AM
Marc's Avatar
You mentioned the rpms were only about 2500. With fly by wire, this is usually what the engine will rev when out of gear. Rolling in gear on the road, it should turn about 6,000.
Old 12-05-2015 | 05:57 PM
Toybreaker's Avatar
Yeah and under load it only pulls to 2500 then the ses starts flashing and running like absolute ****
Old 12-06-2015 | 09:14 AM
JagV8's Avatar
If that's the MIL then it's saying misfires so bad they're cat-damaging then and there.
Old 12-06-2015 | 03:45 PM
Toybreaker's Avatar
Yeah, Code stored after that is P1316 or whatever the cat killer is.
And why is it doing it?
I have to reload my scanner onto my laptop to get live data stream back to check the fuel trims....
Old 12-06-2015 | 04:33 PM
JagV8's Avatar
Then you can check if it's a leak and if so go hunting for it.
  #28
Old 12-06-2015 | 06:07 PM
Toybreaker's Avatar
I have done a smoke test, as well as test with brake cleaner. no indications of a break in the intake tract after the MAF.
Old 12-07-2015 | 01:28 AM
JagV8's Avatar
But what do the trims show?
  #30
Old 12-07-2015 | 09:09 PM
Toybreaker's Avatar
https://www.jaguarforums.com/forum/s...-4-2-a-154102/
Going to continue this line of troubleshooting/repair on this thread.
  #31
Old 12-08-2015 | 07:25 AM
Marc's Avatar
Ditto on the fuel trims for me Toybreaker. Lucky for me most all of my rough running issues on our 2 Jags thru the years were resolved with the replacement of one or more ignition coils, zip tieing the connectors here and there, (mainly the throttle motor). and re-timing and associated repairs to the exhaust cam left bank.
A quick check thru the Jag engine stalling reference reminded me of the importance of having the right spark plugs. If the OHM is different, the PCM, ECM ECU whatever, won't read correctly. The other thing comes to mind is the sealing of the air boxes, since the flow thru dictates the fuel and spark delivery. Something else that seems to mess with peoples heads is the grounding of the battery to the engine block and particular sensors. I have seen grounds contribute more than their fair share of weirdness. Just because they crank over, might not mean good enough. Sorry If I am repeating what anybody else has already stated.
  #32
Old 12-08-2015 | 04:50 PM
Draven's Avatar
Default Battery and TPS
What kind of battery did you get???????
  #33
Old 12-08-2015 | 04:52 PM
Draven's Avatar
And what is your voltage on the TPS
X_Type_South_Africa
12-09-2015 05:37 PM
ControlIssues
09-03-2015 07:38 PM
ogorir
09-03-2015 07:34 PM
RayJackson
XK120 XK140 XK150
08-31-2015 09:39 AM
stanjag
08-30-2015 10:35 AM
Quick Reply: Inherited NA S type with a bunch of issues
