Injector Connection Removal
So..I have not figured out how to start a new post...so adding to this one...I have a major gas leak at the connection to the fuel injection rail on the drivers side. Was pulling the incoming gas line hose and caused the damage...Question: how do you remove the cylinder connection that enters the injection rail... thansk john
Received 6,365 Likes
The fuel is spraying
Thanks for the help with the tool to disconnect the incoming fuel line. I noticed that there is an air intake valve on the incoming fuel line...It has no pressure...should it be under pressure when key is off? The replacement part is $167 which looks like it tracks all the way back to the fuel pump close to the firewall.
So if fuel is spraying when key is turned on at the fitting into the fuel rail the answer is removal and replacement with the factory part???
sorting out the best plan..thanks
fuel is spraying
Got the incoming fuel line off...tool worked great...unfortunately there is a crack at the base where the fuel line connects. Looks like it is all one piece as part of the fuel injection rail.
Question: can you weld the metal connection if I remove the fuel injection rail?
Question: any special tools need to remove the drivers side fuel injection rail on the 2003 S type 4.2 V8 ? thanks john
clubairth1
29
05-10-2024 12:57 PM
trosty
26
12-18-2022 06:40 PM
aholbro1
08-05-2021 05:02 AM
