Inspecting S-Type f/r suspension
>Thank you for sharing
Sure, was happy to
But that video does raise an interesting question, how frequent are those suspension wear problems with our cars? The fellow in the video describes them as being very common on S-Types. But, I don't remember much mention of them in this forum.
So, how many of you out there have had to replace any of the components covered in the video? Particularly, in my case, how common are tie-rod failures?
I actually started looking stuff up a couple of days ago when I had snow tires installed on the rear of my car. The tech in the tire shop told me that both tie-rods needed to be replaced. And when they moved the car I believe I saw the front wheel shift forward and back when the applied the brakes (i.e., move in relation to the fender, not up/down).
Jaguar: Grace, Pace, and Space - Sir William Lyons
Sure, was happy to
That's very helpful, but what I wonder is why he didn't at all mention A-arm bushings up front? I thought the uppers especially were prone to bushing wear. Perhaps wear and failure patterns depends on road quality, type of roads, weather, etc that the car experiences over a lifetime.
Thanks for the post though, I'm going to have a look on my S-type.
It just depends. I would not say any of that is common EXCEPT the front sway bar bushings on the GEN I cars. Next most common is the sway bar end links on the front and then the rear. Both of these are pretty cheap and easy to fix.
My 2005 STR has 108K miles and everything down to the tie rod ends are factory. Perfect alignment and no noise or rattles. Now I do have some torn rubber boots so water and grit are getting into the joints and for sure are causing wear.
But when I need to replace anything is still unknown.
Suspension repairs? Suspension repairs? ::in my best old 90s SNL sketch voice:: "I gots yer suspension repairs right 'ere."
2003 S-Type 3.0, 136k miles: Front upper ball joints (d & p sides) replaced with upper control arms (factory-pressed) last month. Lower ball joints too. Rear stabilizer bars (d & p sides) this month. All four wheel bearings (2 just for good measure) a couple months back. Just wear-and-tear given the mileage on the vehicle.
scooternva
20
09-27-2023 11:25 AM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
