Install JTIS on Windows 7 x64
I installed JTIS today on my Dell Windows 7 Ultimate x64 box and it works fine.
Here is what I did:
Follow the download instructions at:
https://www.jaguarforums.com/forum/s...ad.php?t=16261
Unzip J-CD1.zip to any folder you like on any hard drive you have.
Now, within that folder that you just unzipped J-CD1.zip to will be a folder called J-CD1
Burn that folder (J-CD1) back to a CD and make sure its "finalized" ... meaning its not a multi-session disk, its locked, no more files can be added to it later.
NOTE: I did not try to burn just the contents of J-CD1, I burned the whole folder.
Run Setup.exe from the CD that you just burned the J-CD1 folder to and it will install and run fine.
NOTES: I used Nero Express to burn my CD so I don't know if using Win7 to burn the CD will work or not, I assume it would as long as you finalize the disk.
Here is what I did:
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
