Installing a sub, can you piggy back of stock subs?
I tried running the stock subs and also a line level converter to my amp and sub box and it sounded like crap. The additional impedance load on the stock amp caused it to distort prematurely. I ended up doing one or the other(running only the stock amp to my line level converter or running just the stock subs). I even ran the stock amp to my 12" box and it sounded a million times better than the stock subs. That may also be an option for you. I ran the stock amp to my line level converter with a 12" sub box and removed the stock sub enclosure most of the other time. It freed up a little room in the trunk and the openings for airflow/bass to travel through probably didn't help either.
That is kind of my thought.....I might even try to port the box and make it fire through the old sub holes.....Have to get in there and tear it out to see if it is worth it....
Just want it to hit better than stock and still controll it via the "stock" controls, and with the JL Audio bass knob
Just let it play in the trunk, and remove the factory sub in the deck to allow it to pass into the cabin. FYI - your deck might rattle, mine does with a single 12", but I haven't taken it apart to see why yet.
George
I am gonna gut the trunk and dyno mat it all.....and when I mean port holes I mean take it out.....and leave the holes open to pass the air through.....the box will be built to sealed specs.....Just want xtra bass and not rattle the car to death....
I have 2 JL Audio 13.5W6V2's and 2 Alpine Type R's in the closet......
The one lil 10W7 will be more than enough
99xk8guy
06-05-2023 06:28 AM
