Intercoolers: clean or leave as them alone
Is it good to clean the intercoolers (at 67Kmiles) while they are off or best to leave them alone? If they should be cleaned what is the best method and name of the cleaner(s) to use.
Reference:
https://www.jaguarforums.com/forum/s...e8/#post530393
I apologize. I can't seem to edit my title error...
Intercoolers: clean or leave them alone?
Reference:
One trick I have used for years.
After using a degreaser what's left is mainly baked on carbon. Get some oven cleaner (Not the fume free kind!). This will eat up the carbon. Wear gloves because the caustic will burn the skin and eye protection. It will dull polished Aluminum too but this is not a problem because the intercoolers are not polished.
Just remember if you don't remove the grease first you won't have much luck removing what's under it. If you apply it several times then the first couple of cycles gets the loose oil/grease off. Much faster to cut the grease first and get hard dry black deposits to let the oven cleaner work on.
I find the Wal-Mart in house brand to be the strongest and cheapest oven cleaner.
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
