That ipod in s type thread again
I have the stock radio from my car, but I went aftermarket a long time ago, and don't have the proper wiring harness to connect to it (I'd need a pigtail from a wrecked car or something) in order to figure it out.
Take care,
George
Even if it is digital could i still solder directly to the board in the cd unit and play silent cd for aux out ,I have done it like this on several stereos but would not want to risk damaging the unit.i have sat nav ,and multi cd changer in boot ,not sure if its digital or not is there an easy way to find out ?
Take care,
George
On an non alpine stereo car - which uses analog, not digital audio output, It's probably that easy as well. No one has ever really take one of these radios apart to figure it out like the GM / Ford guys have.
Take care,
George
Take care,
George
The butcher the changer hack is for the older generation alpine setup which used an analog audio connection for the cd changer (these cars all had a cassette deck in them).
The Modern CD changer is still fiber optic. As is the connection to the nav screen and nav dvd drive. There is no connection to butcher. Btw you dont have to cut into the cd changer to do this on the older cars. All you need is a male - female alpine Ai-net cable extension that you can hack into and place it between the CD changer and the radio. That's what I did on my Arden Xk8. Completely reversible.
I always knew these type of systems (nav without alpine option) existed but here in the USA you could not get satnav without the alpine stereo option.
Take care,
George
Hi Everyone,
I have been reading the forum for nearly 2 weeks now and i am still confused as to the answer to the 640000000 dollar question.
How can i cheaply get ipod to play through s type jaguar head unit.
On several of my previous cars i have just solderd an audio out jack to the amplified cd output on the radios circuit board .Play a silent cd and the ipods music would be played over the cars stereo.
Would this work on my jaguar ,i have the cd player with nav screen with cd changer in the boot ,no amplifier.
I have seen several ways people have got ipods to work but what is available on the s type.
I have looked around the forum for answers honest.
yeah think i am going to have to use a parrot blue tooth device ,they are a little pricey though.I already have one but is only for the phone and has no way to bluetooth music,what one are you using ?and will it play out of all the speakers .
I installed the Tranzit Bluetooth device in my 2003 S-Type -- fairly easy install and pretty good sound, not as good as direct connect, but certainly okay for me!
https://www.jaguarforums.com/forum/s...e2/#post865710
Hi Everyone,
If you have the NAV screen you have to get the Jag ACM. It has the connector for an Ipod but has other connections as well.
Otherwise you have many more options.
SEARCH it's all there.
+1 try one of these it charges or you can use it wire free off the ipod battery for about 4 hours [ i checked that] good reproduction, worth a punt???Wireless FM Radio Transmitter Car Charger Remote For iPhone 3Gs 4 4S iPod Touch | eBay
Thanks for the replies, the acm route is a no go due to cost and the way it displays albums from ipod, I have used fm transmitters before and in my opinion they have been very hissy and not very good at all ,I think I binned mine after a day , might go for a parrot kit but that's going to be close to £200 pounds,
I think what I realy want to know is ,has anybody just soldered an aux out put jack directly to the single CD player in the fascia ,like I said I have done it on numerous cars before but I have always known where to solder from previous people who have done it .
Please note I have searched and searched this topic to death so I understand people saying use the search and find it mentality but believe me I have .
Be careful with the Parrot kit, you only get good quality if you connect the stereo audio through an aux. input (back to the same issue). The internal power audio amp is not very good quality driving speakers directly.
+1. A good quality WIRED FM aux. adapter can be indeed very good. It is relatively easy to install and inexpensive. I have been running one for years in this car (with nav.) with great results. It is the WIRELESS ones that are crap.
Not sure what you mean about the internal power amp issue ,my car has not got amp in the boot ,and audio sounds good ,must admit the parrot kit looks good if a little pricey,
Thanks for advice
There are two way to install the Parrot: Either directly driving the speakers or driving the stereo through a line level Aux. input. If you set it up to directly drive the speakers, it completely bypasses the car's audio system and uses it's own (not very good) amplifier. If you install it for a line level aux input, you will get good results but you need, well, an analog aux. input, which puts you back to square one.
Lawler999 (01-21-2014)
