Issue after J004 Recall - faults & no start
Two days after having the J004 recall (both ECM & TCM updated) done on my 05 S-Type 4.2L, I went to start it up in the morning and the engine would not crank. The dash lights lit up and I got a boat load of fault messages (e.g. Engine System fault, Park Brake fault, DSC not avail.). I disconnected the battery for a few hours and it started up fine after reconnecting. With all the moisture related posts found in the archive, I should note that it had been raining the previous day and I had been driving it w/o the belly pan as I was chasing down a minor coolant leak in the DCCV area.
I guess I'm thinking either they damaged one of the connectors when doing the update or didn't get one of them back together properly and this allowed moisture to interfere...?
Can someone indicate which connectors they interface with when doing the updates so that I can inspect them? Does anyone have any other ideas or info that would be helpful?
Many thanks!
Bob
Many thanks!
Bob
Brad, if you have the factory Jaguar battery, I would start there. A failing battery causes a host of faults and codes. Just a few months back, us 2005'ers have had to replace the factory battery.
Brad, I was reading new posts, you added in the XJ section that you were "having the same problems" is your S Type getting the limp home as well?
joycesjag...I do still have the factory battery in my car and will be trying a new one in the morning. I have detailed post i made today with all the information about my faults.
https://www.jaguarforums.com/forum/s...ad.php?t=37894
