Jag ATF table from Valvoline site
Old 03-15-2015 | 11:49 PM
car5car's Avatar
Default Jag ATF table from Valvoline site
That is what I'll use.
Old 03-16-2015 | 01:46 AM
Cambo's Avatar
A couple of glaring mistakes in that table. I wouldn't trust it...
Old 03-16-2015 | 09:17 AM
leaping cat's Avatar
MAXLIFE ATF is perfect for the Ford gearbox but not for the ZF
Old 03-16-2015 | 02:01 PM
tbird6's Avatar
Since the ZF Lifeguard has come down to the $19-$20/Liter price I just use that. You will only buy a few liters over the life of the car.
Now when Lifeguard was $50+/liter then I looked for other fluids.
Old 03-16-2015 | 08:36 PM
car5car's Avatar
I'll buy ATF from that table and let you know if anything goes wrong.
Old 03-16-2015 | 08:45 PM
NBCat's Avatar
With the price of ZF Lifeguard6 coming down significantly, you may want to reconsider using the ZF fluid. The cost of overhauling one of these gearboxes is substantial and used ones are dodgy at best.
Jumpin' Jag Flash (03-17-2015)
Old 03-16-2015 | 08:51 PM
car5car's Avatar
Are you saying wrong fluid can damage AT?
Old 03-16-2015 | 08:56 PM
NBCat's Avatar
I believe the answer is in the question.
Old 03-16-2015 | 09:03 PM
car5car's Avatar
Which parts will get damaged?
Old 03-17-2015 | 03:33 AM
JagV8's Avatar
Will depend on what's different, won't it? Sort of meaningless question.
Old 03-17-2015 | 03:53 AM
plums's Avatar
To be a bit more direct, using the wrong ATF can result in damage to
the friction discs as a first candidate, and then the rest of the
mechanism.
You seem to have a 2003 V6. The specification booklet calls for
Shell M1375.4
If you plug
Shell M1375.4 maxlife
into a search engine, then you can do your own research and
come to your own conclusions.
slojotaa
10-16-2019 11:22 AM
SteveSheldon
UK & Eire
505
07-14-2016 05:48 AM
Holden
09-05-2015 04:29 AM
Chet Ramnarain (bozzner)
09-03-2015 08:47 PM
MC36
US Lower Atlantic
09-01-2015 08:34 PM
Quick Reply: Jag ATF table from Valvoline site
