Jag jumps when changing gears
Old 03-18-2007, 10:57 PM
racerx82's Avatar
Default RE: Jag jumps when changing gears
lol, lets hope he returns..
  #30
Old 07-01-2007, 10:30 AM
is the car lurching foward.. at what speed? or when you downshift you have a harsh downshift? ... into 1st .. it seems all there doing is clearing the shift adaptations and reprogramming the tcm and ecm... really not gonna fix this... do they know if the correct software is in the tcm...? the car needs to be cleared of the shift adaptations.. then has to go thru coded access .. thru jaguar hotline..
  #31
Old 07-01-2007, 10:32 AM
or can be a fuel trim issue...
  #32
Old 07-03-2007, 02:11 PM
badmojo's Avatar
So they replaced the tranny and you still have the same issues?
  #34
Old 07-05-2007, 12:46 PM
What a fiasco man, best of luck to you man, I'm having issues with my own car that won't quit either man, hang in there and best of luck to you man, keep um honest, or try to !
  #35
Old 07-05-2007, 04:01 PM
ken@britishparts.com's Avatar
That is the other side of cutting edge. The upper end manufacturers invent all this stuff, then the other manufacturers copy it once the kinks are all worked out. Since they are the umpteenth company to better the design, it works better. Creativity is tough, making a quality copied part makes cars affordable for all of us. Remember the day when only those fancy cars had electric windows? No, it's hard to find a car without them!
  #36
Old 07-06-2007, 09:16 PM
reddrawf's Avatar
ORIGINAL: badmojo
That's what I was wondering? It seems good that they replaced the transmission, but amazing that the problem wasn't solved. I'm glad my 2003 doesn't do this. However, it does sometimes seem to lurch when I come to a stop. As I press the brake the car feels like it jumps foward a bit.
  #37
Old 07-07-2007, 12:06 AM
badmojo's Avatar
My 03 str does the exact same thing. When the car is just about to stop I get a slight jerk forward. What I think it is is the car downshifting into 1st gear just before stopping giving the nudge feeling. Next time you drive pay close attention and see if you think that this is what yours is doing.
  #38
Old 07-07-2007, 06:52 AM
04Xtype's Avatar
you could try the manual shifting using the jgate, so when u want to come to a stop slowly shift down on the jgate and see if you still get the "nudge feelin"
  #39
Old 07-07-2007, 07:47 AM
badmojo's Avatar
Since the J gate starts at 2nd gear it still shifts in and out of 1st automatically and still does the same thing. If I just roll in first and then stop It doesn't seem to do it.
  #40
Old 07-07-2007, 06:25 PM
the new trani probably still has the old software in it..
Quick Reply: Jag jumps when changing gears
