jag timing chain tensioners? plz help?
can someone please help me out i just need to know what size the new aluminum housing smaller timing chain tensioners bolts are my kit didnt come with any and also i found only one guy that said the early lincoln ls 3.9 kit works not the later one is this true please help
tbird6 - I believe (if I recall correctly) the newer style tensioners utilize slightly shorter bolts. To the OP - go to the auto or big box store and purchase shorter bolts - just match up the thread size (it's metric for sure)
i sent it back and got a new kit and it came with 3 bolts not 4 but thats ok i went and bought the grade 5 bolts and works great also got the new kit for $172 plus $10 shipping and didnt need to buy the high priced tools made my own and the car works perfect and smooth now thanks everyone who helped out
JimC64 (11-30-2014)
Received 6,354 Likes
1.00 x 35mm grade5 bolts from homedepot i believe they were $1.19 for two in a pack and the timing kit i used the 2001 lincoln ls 3.9L part number is TK4162 from DNJ ENGINE COMPONETS very well made kit but i got it from rockauto i just checked and they are all out again they cant keep them in stock so keep checking one will come up soon i know mine did and i grabbed it or you can get it from them direct DNJ ENGINE just call them they are pretty cool always a good help hope this helps everyone out instead of buying the expensive kits they want to mark up so high just to make money off of people well thanks again everyone for your help she still running great and nice and smooth likr brand new because i never drive it hardly she just sits mostly in the garage she just hit 101,000 miles tonight driving her home from the shop
Norri (12-01-2014)
just incase if anyone is wondering the crankshaft bolt is 150-180 ft. lbs. and the camshaft gear and vvt gear bolts are 80-90 ft. lbs. i did 180 on the crank bolt and 90 on the cam and vvt gears with blue locktite on the crank bolt got info from jag dealer found a really good guy to help me out there good tech guy was very helpful my advise is to take your time and triple check your work and turn crank by hand two full turns and check again before putting back together i always triple check my work so i dont come out with extra bolts lol anyways good luck everyone i hope this also helps out
Received 2,266 Likes
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
