Jaguar 2000 v8 - s type- no start
Hi
sub- jaguar 2000 s type- v8 engine
i drove home and stop the car, and i will not start the next day.
symptoms-
1. engine cranks, seems like no compression.
2. fuel rail px good.
3. removed plug on pax side bank and checked for compression, no compression.
4. ignition is ok.
5. removed front timing chain covers, all tensioners and chains intact and not jumped teeth.
6. Last day on the way home felt like engine was not developing sufficient power.
What are the remedies i can try to fix it or change the engine.Also after removing inlet manifold noted too much oil deposits .
Guys please help with input.
rgds
Mel
symptoms-
4. ignition is ok.
rgds
Mel
2. i only removed one plug and did the compression check to ascertain if the secondary timing chain is busted.I have confirmed now all the chains and tensioners are in good shape( replaced them 2years ago)
3. removed all the plugs while cracking , keeping the finger on any plug hole you dont feel any compression on the fingers.
pls help
Using your finger practically impossible on a v8. Even so, is your finger a gauge.
You've taken the front cover of without checking for a spark ??
seems a strange way to diagnose a non start.
check for fuel pressure. Check injectors are firing, check for a spark, check for fault codes. Then get a compression gauge
then tell us your results.
if it happened exactly as you said it's not going to be bore wash.
unless it didn't happen as you explained.
post back your results
1. Fuel delivery, all fuses checked satis. Pump runs as advertised,i will check and attack the fuel pressure in the mean time.what shud be the fuel px on the rail with ignition switch on 2 position.
2. injectors are ok along with ignition.
3. checked compression on all cylinders after cranking few times is almost zero.
rgds
Ok Gurus here is the scoop again
rgds
rgds
i plugged the OBD post this issue no codes or CEL was on. FYI
JagV8 isn't p1582 immobiliser related ? I can't remember but remember it was a common code to see back in my youth.
no compression. Remove plugs. Few squirts of oil down each bore. Remove fuel pump relay. Spin engine over. Refit plugs. Refit pump relay. Remove all carpet obstructing throttle pedal. Now put foot flat to the floor and crank it over. It should start.
1. I too suspected it was bore wash, and cranked the engine several times with gas pedal to metal to cut off fuel injectors, still no help.
2. suprisingly when you motor engine cranks with a funny sound like none of the valves are working.
3.I will try the oil squrt methord during the weekend and update the results.
Note- is this the ill effects of the Nikasil coating? I dont have the immobilizer code at the moment.What will that do in respect to engine starting?
rgds
rgds
If you think it's nikasil problems you've got a time machine. Keep it safe.
I was selling an xkr with an early engine and one guy didn't want to buy it because it was an early engine with nikasil. Do some research, racing teams used it. The fault wasn't in the manufacture, it was high sulphur content in the fuel, which no longer exists.
