Jaguar heating blowing cold on driver's side
Welcome to the forums Stephen,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Here you go, a troubleshooting guide for the climate control system:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Specifically, do the test of the DCCV as detailed in post #2 in that guide. These valves have a very high failure rate. They are spring-loaded to the open position (full heat) but it's also possible one side is stuck in the closed position.
Also, increase the selected temperature until HI is displayed. This manual mode bypasses most (but not all) of the automatic control functions and is great for troubleshooting. This helps determine if the DCCV is getting a proper command or if the valve is sticking.
in2town
06-14-2010 07:07 AM
