Jaguar S-type 2001 - Which engine is it??
Hi
So i bought an S-type with a bad headgasket. The previous owner told me, at some point the old 4.0 v8, the car was born with, was changed out to a newer 4.2 v8.
I can for the life of me not figure out what kind engine model the 4.2 v8 is..
When i google, i find this picture from wiki, which is exactly the same as mine.
I've tried to google around other Jaguars, but i cant find any engine, with the same engine cover as the above.
Please help out a frustrated jaguar owner.
Thank you
Thank you
My first thought is the swapper transferred all the original external bits (such as the cover) over to the replacement engine. If they will fit, he likely swapped the manifolds, throttle body, various sensors, wiring harness, etc. Could be the only parts not original to your car are the block, heads, and other internal parts.
I've swapped engines in other vehicles and that's how I did it. It's best to configure the replacement engine as close as possible to the original. It's usually an easy matter to swap external components between similar cores.
I've taken off the heads and as far as i can find from the stamps on the heads, they are original 4.0 heads.
So in that regard, it should be fairly easy to buy spare parts for it... right?
kr98664 (06-12-2022)
Nour
06-05-2017 12:11 PM
WillieE
19
11-21-2015 05:26 PM
