Jaguar S Type not starting
Hi, I recently started having issued with my jaguar. It is a Jaguar S Type 3.0 year 2000. First the windows from both back doors stopped working they dont go down anymore only the driver and the passengers work. Also Everytime I unlock the door with the key it locks right back and it only unlocks the driver door and not the rest of the doors like it use to. So then that same day when i tried to go out again the car didnt start anymore, It makes the noise like it wants to turn on but it doesnt. I have tried disconnecting the battery but no luck. I cant re-charge it because the trunk will not open to see if thats the problem. Can anybody help me with this please ?
thanks in advance
thanks in advance
Received 2,263 Likes
for some reason the key doesnt work in the trunk. I bought it like that so the previous owner must have damaged it. Can the battery be a big factor in it? My boyfriend tried to take it out thru the inside by takin the seats down but he couldnt but if that can be the main issue i can tell him to try again?
Received 2,191 Likes
You say that the car makes a noise but does not start. What kind of noise does it make, clicking, grinding? As for the key not opening the trunk, if it is the green key it is the valet key you are using it will not unlock the trunk use the black key. The hole is under the Jaguar plate above the license plate. You say the battery tested good and was charged and started the car once but not again. If that is the case how long was it between then and the second time you attempted to start it again?
I THINK YOU NEED TO CHECK THE HIGH VOLTAGE FUSE BOX THAT IS LOCATED NEXT TO THE BATTERY. The lead from the battery goes directly to it. It has a total of 3 fuses! This is high voltage and should be handled with caution. Examine the fuses with the battery terminal removed from the battery. We found several blocks were broken when the tire was removed or installed in the trunk causing the fuses to become loose and broken resulting in no start.
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
the car does crank but it just doesnt start i have a black key only im not sure if its a copy but thats the one i have since i purchased the car and i also dont have the remote either. i still cant get the trunk to open i have tried pullin the emergency lever from the inside and still wont open any other suggestions on how i can get it opened ?
after i put in the battery earlier today it did start but it seemed liek it wasnt getting enought gas i let it run for about 5 minutes and turned it off and maybe like 1 minute later tried turning it on again and once again it didint start on me i dont know what to do im going to have some one look at the fuses in the trunk tomorrow hopefully its that![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
I just tried it again and still doesnt turn on just cranks. but also when i have the key in and the hood open ders like a buzzing noise and also when i unlock the door and it unlocks itself the front lights blink twice. just posting more info maybe this has something to do wit it ?
thanks everyone thats helpin me by the way i appreciate it
Received 6,310 Likes
Run a fuel pressure test. By that i meen you can do it. Locate the schrader valve on the fuel rail(someone get a pic for her, and v8 or v6?) turn the key to the on position and depress the fuel rail shraeder valve, if only a little fuel dribbles out or none, you have a fuel pump issue. It should squirt up a couple inches. Or you can take out the back seat bottom cushion and access the pump under the black cover on the passenger side. If the pump hums when you turn on the key then move to something else. But my money is a fuel pump issue based on you descriptions....check the fuse for the fuel pump in the trunk fuse box, i dont remember the 1 but check em all. If its blown its not a fuse problem its the pump pulling too many amps and or internally shorted. Replace the pump and the fuse.
Also the button is the glove box does not open the truck, thats the valet button and if its pushed in you wont get in the truck without remote or key. Otherwords you disable the dash switch and trunk lid switch for valet...
And enthusiast. Test the alt can be done on the car after started, its way to much hassle to pull off just to bench test
