jaguar s type problems
Check for Original coils
Make sure your mech technician applied original coils. If you put some Ford replacement coils, there is a thread that is not the same measure and the ground cable will not reach a neutral current so will not work. This rpm unstable are very common after coils and its plugs had been damaged by passing heavy rainfall accumulation. If you want to hear the failure to make sure is firing problem, take the trac control off and put the gas to a drag speed take off, you will hear the missed firing. It should burn some tires if engine/transm is ok.
Thanks for all who tried to help , I have now pushed her over a cliff and she is now lost to the sea , I have had two jags now with exact same problems with both , my jag days are now well and truly behind me good luck to all the die hard jag fans but never again for me I'm afraid , like I said not for me does not mean not for you all thanks again .
Received 6,361 Likes
Hello, i Had that problem. I tried everything. Computer always went to same cylinder. Everything was new. You know what was the problem? Replacement coils and plugs, not original ones. The screw slightly changes. I put original ones and i can burn my tires again with the trac control off and some heavy take off!
#30
Yes, you can add your vehicle details to your signature so we don't have to waste our time asking what year, engine etc.......
Oh and welcome to the forum. You might want to stop by the "New Member" area and properly introduce yourself per forum protocol.
Jumpin' Jag Flash (10-15-2016)
#31
check my posts - I posted that part number...
#32
All,
I am interested to know the end of the story as my S have similare defect since.... 4 years without any solution. The only positive aspect is that I saved fuel.......
The idle is instable. No fault code and lake of power.
What is the correct range value I should read on 02 parameter with an OBD tool?
#33
richard toulouse (10-14-2014)
#34
restricted performanve
At slow speeds my s type diesel goes into limp mode. The fault code indicates accelerator pedal. Have tried a new pedal...problem remains. Crazy thing...I can drive for 50 miles no problem. Then suddenly this problem starts and continues for upto 30 minutes. Anyone any ideas or solutions?
#35
#36
Received 2,266 Likes
stanjag
08-30-2015 10:35 AM
swarm27
08-29-2015 07:37 AM
Terrance Williams
08-26-2015 11:50 AM
