Jaguar S-Type R
Old 03-07-2010, 04:27 PM
gbit's Avatar
Unhappy Jaguar S-Type R
hallo guys i have a jaguar s type r and i think i have a problem but i am not sure cuz i got this car a mount ago so when i pres the gas hard like if i want to accelarat fast the car dosnt not change 1st gear the arrow going all the way before the redline but dosnt change and when i relise the gas padal then change if i drive it normal like if i press the gas when the car already run like 5mph or 10mph there is no problem but if i try to lunch the car dosnt work that way i dont know why i was reading some stuff about forbbiden drag racing i am talking about the computer of the car so i dont know is there is a transsmition problems or thats normal cuz the car is 400hp got a fly the car has a high performance and i dont know is that normal help me out thx
Old 03-07-2010, 07:34 PM
budsang1's Avatar
so it accelerates to redline, but doesn't shift to second?
Old 03-07-2010, 10:00 PM
Riski's Avatar
Try spell check and periods next time, then I shall read it to figure out what your issue is,....
Old 03-08-2010, 02:46 AM
gbit's Avatar
it look like the gear get stack i have to release the pedal to shift 2gear cuz when i lunch the car start accelarate and until i get the highest rpm like i am on nutrial unles i relase the gas pedal then i change gear
Old 03-08-2010, 03:17 AM
JagV8's Avatar
Received 4,531 Likes on 3,941 Posts
Where in the world are you?
What year car? Mileage? Any mods?
Please use punctuation. Now it's too hard to read let alone understand.
Old 03-08-2010, 06:13 AM
JOsworth's Avatar
The gear gets a stack of what??? What the heck is the car doing going out on it's own when you eat lunch?? And I thought Toyota's sudden acceleration was an issue....
Old 03-08-2010, 07:27 AM
budsang1's Avatar
english must not be his primary language...at least I hope it's not, it's tough to figure out what's going on though
Old 03-08-2010, 07:59 AM
Bull27's Avatar
gbit: Obviously English is not your primary language. Do us a favor and open Micosoft Word, write your responses, do a spell check, then copy, paste and post the corrected response on the forum. We really cannot understand you, or what is going on. This way people will be able to help you.
JagV8's Avatar
Possibly, though with words like "cuz" I rather doubt it. He still could - and should - use sentences.
Old 03-08-2010, 08:48 AM
Received 2,263 Likes on 1,845 Posts
My guess is he's on a crackberry or similar. Uzed to gte simular mesges from a coolegge uuhh cawleege uuhh cow-orker weni wuz wurkin.
Old 03-08-2010, 09:23 AM
JagV8's Avatar
And has, and drives, an STR
Old 03-08-2010, 10:30 AM
Riski's Avatar
You mean haz cuz itz maks lotz of puhwahhhhhh
Old 03-08-2010, 10:40 AM
gbit's Avatar
when i press the gas pedal ,look like the gear box hold 1st gear more then enought dosnt want to change then when i relise gas pedal then the trans change 2 gr but its take a little bit more time to do that when i drive normal there is no problem i hope u got it this time guys sorry for miss undarstanding i hate english hahaha
Old 03-08-2010, 10:43 AM
Riski's Avatar
Are you using the J gate when driving or letting the car shift itself?
Do you have traction control on/off? Do you have it in Sport mode?
Old 03-08-2010, 10:48 AM
JagV8's Avatar
enuf ov d kidz spk ahm outa heer
Old 03-08-2010, 03:35 PM
gbit's Avatar
no i dont used the manual shifter i drove the car on "D" the craction control its on and i dont drive on sport mood so shen i press the gas pedal harder then the car its like cuting off and the gear get stuck or something so i have to slow down to chenge the gear automaticlly
Old 03-08-2010, 03:43 PM
super_jag's Avatar
it should shift before redline if floored, Im guessing there is something wrong when you go wot. I would get a reflash or disconnect the battery to reset the functions.
Old 03-08-2010, 03:51 PM
Riski's Avatar
Does the car drive/shift fine when not floored?
Old 03-08-2010, 04:01 PM
super_jag's Avatar
yes...
Old 03-08-2010, 04:29 PM
Riski's Avatar
I dont see how your trans is fine normal driving, and gets stuck at the top of the rpm band when you dont have it in sport mode or man. shift.....
Try doing man. shift and put it into second gear from a dead stop and floor it then and it should shift itself from 1st to second but then you have to shift it into 3rd gear to 4th and so on.....Do it w/ sport mode and traction control OFF.....and see what happens
Quick Reply: Jaguar S-Type R
