Jaguar S-Type V6 Supercharged ?
Hi,
I know this must have been covered , but I couldn't find it. I have a Jag S-Type '02 model with a V6 engine. I have got the lower control arms, front suspension links and my rear sway bar links replaced. I'm also getting my suspension struts and springs replaced with the Bilstein B6 HD's and H&R "lowering" springs. This should improve the handling.
But, at 210 HP and for its weight, this car is grossly underpowered. I was thinking about getting an Eaton M90 or M112 supercharger blower and pulleys. Considering the M112 was used in supercharging the V8 s, would that mate with the V6 engine manifold ? Can I use an "adaptor" for the intake manifold ? Has anyone ever tried this ? Selling this car and getting an S-type R isn't an option for me !
Your thoughts on this please !
taylor_cj2009
taylor_cj2009
Received 6,354 Likes
Unfortunately for a car that old (02-03 ) R-type there might be issues on top of the sale price ! This is a car that I have already had it checked out by the dealer and had the maintenance done with ... quite a bit actually ! Besides , I'm not looking for a big boost..anything around 300+ to 350HP and I'm a happy man ! Thanks tho !
The thing with turbos is the complexity of installing , the heat . Besides, I'll be using this on the street not the track. So, higher throttle at near redline RPM's doesn't make much much sense to me. A roots or twin screw type supercharger would give significant boost even at low or normal driving rpm's !
Received 2,266 Likes
Nope ! Just looking for options ! I would've swapped out for an STR but for the thought of possible maintenance on another old used car after spending quite a bit on my current S-Type ! Besides, I would rather get a coupe or convertible XR/XKR down the line ! Just getting thoughts on this from other senior members here ! A turbo wouldn't give boost until higher RPM's which doesn't do much for daily driving !
There are no off the shelf kits, the cost of fabricating and installing one-off hardware to adapt a supercharger would probably exceed the value of the entire vehicle and you'd still end up with less power than a non-R V8.
Forget it.
What they are telling you is it will be cheaper to dump your old 6 cylinder and buy an STR. You will spend thousands of dollars and you will still have the older more troublesome S Type.
You want to avoid the 2000-2002 cars regardless of condition. It's really worth the money to get the updated S Type. Jaguar truly did a massive upgrade even though the car still looked almost the same.
