Jaguar S Type V8 2004(Rear Parking Aid)
Just checking if anybody else has had the same problem and what could be the fix, dont want to go to the main dealer...![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Hi my Rear parking sensors have just packed up was working fine, now just get one tone that stops after about 10 sec when put in reverse, my electrochromic interior rear veiw mirrors gone also think this is linked, need help?
steve
steve
I would check that the sensors are making noise. Get someone in the car with the brakes on and put it in reverse. Have a second person put their ear to each sensor on the rear bumper. They should be emitting a high pitch squeal that you will hear if close. If any of them are not they are bad or they have come unhooked. If none of them are making noise I would plug and unplug the parking sensor module which is in the trunk spare wheel well. If that does nothing you may have a bad module. There are several modules in the trunk area. You should get the JTIS off of EBay for about $10. This is really necessary. The JTIS has a nice diagram of where all the modules in the car are located.
I would do this before taking it in. Unless you have a warranty and then just let the mechanic fix it.
Did you do what I told you to do??
Please report back with the results. You should be able to rule out the sensors pretty quickly. Also look under the electrical guide in the JTIS which is different from the service guide. Both are on the same disc. They have the circuit diagrams so you can trace the wires.
They are radar / sonar sensors and like mentioned above, you can check their operation via putting your ear next to them while someone holds the brake with the car in reverse.
Take care,
George
Thanks George for pointing that out!
Good idea to clean the sensors of any dirt/debris. I have attached the wiring diagram for this system and a picture of where the module for it is. This is not a complicated system and really it's usually a sensor or wire to a sensor problem.
Regards Steve
bens:
In in the first post I made I suggested checking for noise at all the park sensors. You found one not making a sound?? Why replace the most expensive piece in the whole system first? Is the dead sensor even hooked up? Can you swap the other sensors around and make sure it is the sensor?? Wiring could still be at fault and would be a cheap fix.
I would do more trouble shooting before spending money on a module that probably won't fix your issue since the other sensors were making noise. This shows the module is at least working part way?
