Jaguar S Type X202 Error Codes HELP!!
Hello,
I decided after some time to read the Engine Check Light, and I got a "few" codes up on the monitor which kinda make me questione my sanity.
P0112 Intake Air Temperature IAT Sensor - Intermittent signal
P1632 Alternator/charging system - load circuit maltfuction
P1260 Vehicle Immobilized Invalid Ignition key, Immobilizer system fault
P1582 Engine Control Module ECM - data stored
P0733 Gear 3 Incorrect Ratio (This one I think is when the car didn't shift properly to the 3rd gear and I had to restart the car and the probleme went away)
P0102 MAss or Volume Air Flow "A" Circuit Low Input
P2503 Charging System VOltage Low
P0037 HO2S Heater Control Circuit Low Bank 1 Sensor 2
P1647 Heated Oxygen Sensor HO2S 1 Upstream, Bank2 - Control Malfuntion
P1146 Alternator Charge Circuit Low
P1629 Alternator Field Circuit Malfuction
P0328 Knock Sensor 1 Circuit High Input Bank 1 or Single Sensor
P0112 Intake Air Temperature Circuit Low Input Bank 1
Now I am truly afraid of my pockets. :laugh:
Is it bad? I want ot mention that the car had some of this issues when I first bought it. The previous owners were bloody awful, mistreated the poor kitty in the worst way possible...
looks like a typical sporadic code throwing fit caused by low voltage .
a few codes point to the alternator . so test your battery voltage first .
fully charge your battery , then check your alternators performance .
ok now you have all this written down .
and the above is done . and if ok .
clear all codes , and see if any come back with use .
turkay (02-06-2019)
Cambo
01-12-2022 07:08 AM
lertas123
09-02-2017 08:36 AM
Norgards Automotive
07-22-2014 06:30 PM
DeLoached
07-21-2013 07:48 AM
