jaguar stype 2001 autodimming mirror malfunction and the abs braking fault
and dude whats the toothed ring also called i guess "abs ring" or smthng which produces the magnetic pulse for the abs speed sensor.
if u cud kindly pls let me knw its technical name and its exact location..preferably thrugh a picture...
plus if i import this ring... do i need to import the whole hub assembly..
as far as i have checked the net.. hub assembly doesnt has that ring visible...
i dont knw if the ring is located inside the hub since the sensor's wire goes inside...O.o
also, will the blinking traction light be switched off by replacing this broken ring... a "tooth" is broken which i guess isnt feeding with the correct readings
guys pls reply soon.. i ll be flying to Dubai for the parts soon so pls let me knw abt this...
I think I can speak for the other forum members in this post...Please... stop "second guessing" and throwing parts at the problem.
You need to get the code(s) from the abs module. If the traction light is flashing there are indeed issues going on and you most likely caused more havoc by changing the abs related parts that you did without getting to the source of the problem...
We can only assist if we get the necessary requested information.
I changed the front left hub to basically replace the abs speed sensor an the broken ring
Now the traction light is blinking.
Will the computer code tell me the fault.
Pls let me knw the required information u need to guide me.
BrentGardner
28
04-26-2024 03:08 AM
NinoGrimace
08-26-2015 05:15 AM
