KEY FOB Part and fcc #'s
Jumpin' Jag Flash (02-12-2015)
You need the dealer or a locksmith that can program jaguar keys . Thay will plug in a diognostic unit in to the cars obd2 port , and if they type in a dealer code it will tell them the key code ! They can determine the key no from the key cut code ! How ever it will not tell you the MHz of the transponder ! But fear not if you get the correct key and the MHz are rong thay can be easily changed !
Hold down both the lock and unlock button on the key fob
And press the boot/ trunk poper button 3 times
Then release the lock and unlock button!
That will switch it from 434mhz to 315mhz and vice versa .
Once you have the right key with the right MHz it then can be paired
With the car
With the car
Jumpin' Jag Flash (02-18-2015)
Wolfy
05-28-2024 08:06 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
