key stuck in ignition
Old 11-21-2013 | 02:54 PM
capt's Avatar
Default key stuck in ignition
Transmission shifts into park properly. Interlock cable is attached at shifter. Key tumbler has been lubed. The key will pull out around 1/2". My guess after searching forums for a week is interlock problem or key/tumbler problem? I removed the panel below steering column hoping for access to ignition lock assembly and release pin. Yikes! Do I need to remove radio panel in dash for access? Also, I have the shifter assembly loose and not sure if the white plastic block on interlock cable/arm just pops off like shift cable. I was worried about braking something. This is a 2005 s-type final face lift . Thanks.
Old 11-21-2013 | 03:15 PM
tbird6's Avatar
When did this start?
After you started taking things apart? Any idea how worn the key is?
I am just guessing as I have never seen this posted before.
Old 11-21-2013 | 03:37 PM
capt's Avatar
It started when I used my new key. I had the person that cut 3 keys for me look at it but he thought it was a shifter interlock problem?
Old 11-21-2013 | 04:05 PM
tbird6's Avatar
Sure sounds like the key was not cut right? That still should not cause that but I am unsure.
Old 09-10-2015 | 01:33 PM
Stephen's Avatar
Same problem as yours. How did you solve it?
Old 09-11-2015 | 11:41 AM
capt's Avatar
I purchased a new lock and key assembly but still need to install it.
Old 09-11-2015 | 12:22 PM
tbird6's Avatar
Before you install it check your 3 keys to see if they work or not.
Still could be a key problem.
Old 09-11-2015 | 10:41 PM
aholbro1's Avatar
What? Your key has been stuck in the ignition for nearly two years?!?
Or did you find a work-around?
Old 09-12-2015 | 10:26 AM
capt's Avatar
Other key works in door, but not able to remove key from ignition so can not try it? I purchased a complete set of new locks and keys and so far changed trunk and glove box only. The door looks hard due to window removal, waiting for cooler weather and no rain.
Old 09-12-2015 | 10:27 AM
capt's Avatar
Originally Posted by aholbro1
what? Your key has been stuck in the ignition for nearly two years?!?
shhhhhhhhhhhhhhhhhh!
Old 01-19-2023 | 06:26 PM
capt's Avatar
OK, here is a update. To get the key out, use high pressure air and blow in keyhole while jiggling key. It supposedly makes the disc inside move around to release, The dealer did not cut the key properly. The original works fine,
Sheff928 (02-25-2023)
Old 01-19-2023 | 09:33 PM
xalty's Avatar
it’s just hanging on the dust cover because the spine got cut too low.
any strip of metal does the same job
Old 01-19-2023 | 11:35 PM
Scotlad's Avatar
Capt this has to be one of the oldest updates ever! Over 7 years, better late than never.
Dnki (10-10-2024)
Old 01-20-2023 | 02:05 PM
capt's Avatar
That's because I just decided to fix it so I can sell it. It was like these new cars where you can leave the keys in your pocket!
Old 02-24-2023 | 11:02 AM
capt's Avatar
Smile
New update! A not local Jaguar dealer told me to wire wheel the CRAP out of it. It worked! I also polished it with some fine compound so it is very smooth. I hope this helps someone?
The following 2 users liked this post by capt:
Scotlad (02-24-2023), Sheff928 (02-25-2023)
Old 10-10-2024 | 11:00 PM
Dnki's Avatar
Default Out Of What?
Any chance you could explain what you wire-wheeled and polished for those of us who might think you mean the key?
Old 10-11-2024 | 08:18 AM
Peter_of_Australia's Avatar
Ok, since we are reviving dead threads here, allow me to make a stupid remark, which sadly actually just tells it as it is... :
Great. This would have made sure that no one could steal your key for the last few years - at least not without the car attached...
Old 10-11-2024 | 09:36 AM
That's what he did mean.
Themgbarnett
01-21-2022 12:26 PM
yellowbandit
12-21-2020 10:39 AM
amcdonal86
11-18-2018 02:15 PM
david purscell
10-21-2011 07:08 PM
aquill1
08-08-2010 01:30 AM
Quick Reply: key stuck in ignition
