Keyless remote just stopped working...?
Although you really need to know what you're doing to install an aftermarket keyless entry system in one of these cars.
George
if you want to install just a keyless unit, we have the RF225 which can be added to your vehicle by an installer. Wiring and locations are as follows:
Power Unlock BLACK/WHITE (-) INSIDE DRIVERS DOOR
USE A DOUBLE PULSE TO UNLOCK DOORS.
PowerLock BLACK/GREEN (-) INSIDE DRIVERS DOOR
Battery BROWN/RED (+) IGNITION SWITCH HARNESS
Ignition WHITE/GREEN (+) IGNITION SWITCH HARNESS
Parking Lights WHITE/GREEN (+) AT VEHICLE LIGHT SWITCH
Trnk Release BLACK/GREEN (-) AT SWITCH
*NOTE: hooking up the door locks in the above location, will arm/disarm the factory alarm also*
Those are the main wires you will need to have the unit function. Dont forget the ground wire though. Other than that, that would be the least amount of wires to hook up to have it work. If you want more info on the system goto www.autopageusa.com and then click products. That unit can be used as a standard keyless entry or basic alarm. It is programmable either way.
I tapped constant power and ground off of the factory driver's door module. Ign switched is also there. Lock / unlock (including factory arm disarm) are there (and only there).
The drivers door sends a can bus message to the rear electronics module to lock / unlock the car. And release the trunk and or / flash high beams.
No need to do parking lights separately in a Jag. The Rear electronics module flashes them when the car is externally locked / unlocked.
The trunk release can also be tapped at the general electronics module in the driver's kick panel.
I diode isolated the trunk release output and tied it to the factory lock wire, that way if I stand on the trunk release button, the car global closes the windows and the roof. (As if you are holding the key turned in the lock position) The trunk still locks / unlocks with the remote, just doesn't pop. But all you have to do is walk up and tap the button. I hated how the trunk would swing wide open anyway, so I never used that feature anyhow.
Oh and the double pulse you mention is optional, not required. It is if you want "single stage" unlocking, where all the doors unlock simultaneously with the first press of the unlock button. If you want to just unlock the driver door on the first press, and then require an additional press to unlock the rest of the car (my personal preference), you don't need the double pulse.
In my opinion its a much better use of the trunk feature, but all you would have to do is feed one wire through the door into the kick panel if you wanted to "pop" the trunk.
I can give the original poster wiring diagrams and specific pin / connector info if he wants to do this. I have it all mapped out.
George
BKS....I think the only permanent solution is to have it re-programed at the dealer. Any self-programming routines (turn ignition on and off 10 times in 2 seconds with both hands holding each door mirror, etc) are ineffective. Mine worked 1/2 the time before giving up the ghost entirely. I had marginal sucess cleaning out the ignition switch and spraying lightly with WD40...I understand there are instances where the ignition switch "doors" are not closing when the key is removed, thus the vehicle thinks the key is still in the ignition, in which case nothing on it will work. I have the remote re-program on my bucket list when the car goes in the shop next week. I'll let you know how I make out. It's getting old locking and unlocking with the key in the door.
George
I had the same issue as Delta66, the little brass piece slipped to one side. I took the remote apart, slid the brass piece over to where it was aligned properly and it worked great, had nothing before. It seems my wife would always push a little sideways instead of down on the unlock button and worked it loose. Just a temp fix until you can get a knew one.
kabs3012
09-12-2015 10:40 AM
