Killed a rattle.
Old 06-17-2010 | 09:26 AM
Leedsman's Avatar
Default Killed a rattle.
You know how when the weather gets a bit warm and shows up a new rattle in your car? Well I got one in the passenger's door (I sit on the right) and I thought, "here we go again, wasting hours and hours checking this and that and getting nowhere at a rate of knots".
Well, I'm going to blow my B-flat long and strong because I've killed it, and only at the second attempt!
Down near the bottom of the door there is a thingummyjig that looks like a big black plastic bolt head. So I jammed a bit of sponge between it and the door. No rattle! Next I wound it out a quarter inch, checking the door still shut normally.
End of rattle. One less irritation.
Leedsman.
Old 06-17-2010 | 11:35 AM
tbird6's Avatar
Leedsman:
That's great!! Can you give a little more description? I can't place where this bolt is??
Thanks!
Old 06-17-2010 | 12:31 PM
carelm's Avatar
Well done Leedsman,
I went out to my S-Type and found what you were referring to. When you open up the car door it's near the bottom and rear corner of the door. I suppose at a later date you could get some washers to get the spacing you desire.
Mike
Old 06-18-2010 | 02:23 PM
clubairth1's Avatar
OK. Thanks!
GordoCatCar
01-02-2017 02:10 PM
Malihide
04-02-2016 05:05 PM
redxk8
10-04-2015 09:28 AM
yarpos
09-27-2015 07:14 PM
Tim Goz
09-17-2015 10:11 AM
Quick Reply: Killed a rattle.
