Knock sensor
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Hello S type owners... I read the post on replacing the knock sensor on the 4.0 Jag S type, but the 2003 does not figure the same. My code says bank 1/so Bank A/ passerger side. I cannot find a knock sensor anywhere on this side. On the drivers side attached to the top rail is the connector for a knock sensor. I have the replacement part and the connectors are the same and the 2 wire cover is green and black ( the same). It connects there and travels under the air intake to who knows where... the wire length is about 20" ...the connection to the engine is a round rubber 3/4" wide affair with a 3/8" hole in the middle. I cannot find anything to match this on the passenger side !
Any thoughts as to what is next? john...read that both knock sensors are under the intake plennum..will remove it and go from there...
wordman (10-13-2012)
Woznaldo
09-26-2015 11:02 AM
