LED License Plate Lights?
Old 01-15-2010, 05:31 PM
JOsworth's Avatar
Originally Posted by phd12volt
why does everyone keep saying something about the switch??? i have had them in mine for over a year and it does not have any kind of resister needed whatsoever. Nor switch. Weird that people need switches...........really weird
I know Jason.....
  #62
Old 01-29-2014, 05:20 PM
Wuzupez's Avatar
I know this is an old post but has anyone used the Sylvania 6000k led? They are between $10 & $12 each depending on where you get them from. They seem to be a pretty bright white.
  #63
Old 02-02-2014, 10:19 PM
Wuzupez's Avatar
Ok well I put the Sylvania LED bulbs in my plate lights and it looks perfect. Super happy with the color. Looks factory! However, I did notice a slight buzz after installing them. This normal? I had the car off and and park lights on when I changed them out. After pulling the factory bulbs out and installing the LED's that's when I heard a slight buzzing coming from them
  #64
Old 02-03-2014, 11:44 AM
2000JagLvr's Avatar
I have not installed any LED lights on my car yet so I don't know what they require. Do they need to be installed with the correct polarity? I.E. positive to positive.
Check the connections. Are they clean. The socket may have become corroded over time.
You might have a bad ground somewhere also.
Try re-installing the old bulbs one at a time and see if the "buzz" goes away on one or both. If it is only one bulb try swapping them and see if the buzz moves. If so you might have a bad bulb.
Good luck.
Scott
  #65
Old 02-03-2014, 02:41 PM
Wuzupez's Avatar
It's both bulbs and it's very faint. But it's there. Only with the LED bulbs though. And yes they are the correct bulb #2825
Either way they are staying in cause they look amazing!
  #66
Old 12-21-2018, 03:29 PM
95 Cat's Avatar
My plate light lights do not work either on my 2011 XKR. Dealer says it is a module. A $1,000.00 PART!!!!!!!!! The car is under warranty and I am in the process of getting it fixed. RIDICULOUS!
  #67
Old 12-21-2018, 03:42 PM
JagV8's Avatar
Received 4,526 Likes on 3,936 Posts
Ancient thread AND the wrong forum
H20boy
07-23-2021 09:39 PM
daverb
10-28-2015 10:18 AM
raffoulig
09-08-2015 01:56 AM
sklimii
09-05-2015 06:04 AM
bdboyle
09-04-2015 06:16 AM
Quick Reply: LED License Plate Lights?
