LED License Plate Lights?
#61
#62
#63
Ok well I put the Sylvania LED bulbs in my plate lights and it looks perfect. Super happy with the color. Looks factory! However, I did notice a slight buzz after installing them. This normal? I had the car off and and park lights on when I changed them out. After pulling the factory bulbs out and installing the LED's that's when I heard a slight buzzing coming from them
#64
Check the connections. Are they clean. The socket may have become corroded over time.
You might have a bad ground somewhere also.
Try re-installing the old bulbs one at a time and see if the "buzz" goes away on one or both. If it is only one bulb try swapping them and see if the buzz moves. If so you might have a bad bulb.
Good luck.
Scott
#65
#66
#67
