LED PROBLEM
LED PROBLEM
Ha Guys
Iam have a problem getting my LEDs to light up in my taillights. 2002 S type. If you are looking down at the plug that plugsin to the tailights there are 7 wires going in. Dose anyone know what wires need to be jumped by the resistor or resistors.I have tryed everything an no luck. I know Matt did his but his is not the S type. Need some help.
Regards
Regards
RE: LED PROBLEM
with out seeing what youre trying to install, and now that you know its still a neg grounded electrical system....also LED(light emitting diode) and since diode offer 1 way paths is it wired correctly? Many times when Ive seen people put in leds they say 1 works 1 doesnt, flip the 1 that doesnt work over. path goes +to- which meens you can install them backwards, not an issue with a reg. bulb since it doesnt care which way the power flows....follow?
RE: LED PROBLEM
h29
Wish I could say yes but the answer is no. Brutal sent me a wire guide but the wire colors are different. Only thing working is the fog light. I useda 30 led bulb. Looks good. Just got the led bulbs for the directionals with the correct base, off set pins. Haven't had a chance to install yet. They don't make a brake light in red with the off set with 30 leds.Company seeing if they can get one made up. I'am trying to use all 30 led bulbs. I'll keep trying but.
Regards
Regards
