Left front sign lamp failed temporarily
Hello there,
I just got this S-type V8 4.2 (NOT R). And the Left front sign lamp is sometimes on and sometimes failed.
Certainly when it failed, the warning sign will tell you, then suddenly after some left turn signaling, it is fixed again.
Could this be due to the wiring failure ? or may be just the bulb is not tight enough ? Any idea ? Thank you in advance.
Received 6,320 Likes
My 2005 S Type had the same bulb/socket problem. I looked carefully and saw a small slot had been burned in the metal spring clips in the socket that holds the bulb. Changing the bulb did not fix it. I finally folded aluminum foil over until I had a small square of flexible metal. I folded this over the bulb base. Then plugged the bulb into the socket making sure the small piece of foil stayed in place. That was over 5K miles ago and it works fine. I just can’t find used parts for these cars!! There just are not enough of them around!!
RizwanSharp (01-04-2011)
Thank You so Much Norri, I'll give it a try on the Weekend and hope it works for me... If it does not then I'll look how much the new holder is going to Cost (don't know if that kind of thing will be covered by the Extended warranty).
Anyways. Thanks for the heads up. I'll repost after doing what you have suggested.
Best Regards,
Rizwan
Best Regards,
Rizwan
Best Regards,
Rizwan
Best Regards,
Rizwan
But this is what I got from Jaguar Catalog posted by some on forums:
LEFT Side Turn Signal Bulb Holder: Part# XR848363
http://www.oempartcatalog.com/partlo...&siteid=214578
RIGHT Side Turn Signal Bulb Holder: Part# XR812401
I haven't open the holder yet so I don't know If I can fix the exiting one or need a new holder.
Please let me know if it helps.
Thanks & Best Regards,
Rizwan
RizwanSharp (01-07-2011)
See the attached Pic... take from Catalog.
I gave those Part numbers from this catalog and that Holder is highlighted in number 16 (in the picture).
You can call those guys and ask them if thats the actual holder of the Turn Signals.
I hope that helps.
P.S: this is what that website says:
Front lamps - Headlamp components - Levelling motor - Holder
Signal lamp bulb Left - Halogen 2003-07 2003 - 2007
Rizwan
I hope that helps.
Rizwan
Tar
09-06-2015 11:24 AM
