License plate bulb help
Hello all-
Just a quick question about changing out the license plate bulbs. I see that there is a little tab on the lense above the plate which looks like it can be pushed in. Is this how the lens housing is removed, or do you have to access the bulbs from the inside of the trunk (behind the liner)? If it is through those tabs can I just use a flat screwdriver to push the tab in and then wiggle the lens loose or is there a trick on removing them? I didn't want to break the tab, hence me not experimenting with it quite yet. One of the bulbs is out so I was going to replace both.
EDIT: Forgot to add that this is for an '05 3.0. Thanks!
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
