Limp Mode and Dash lit up like a Xmas Tree!
Old 02-03-2013 | 01:57 PM
GonzoJag's Avatar
Default Limp Mode and Dash lit up like a Xmas Tree!
New user with an old problem. My son has my 2005 S-Type 4.0 and lives out of state. Last night the car went into limp mode and got every fault code lit up on the dash. Although it sounds like the battery from doing my research here, I understand it could be a problem with the throttle body, MAF, etc. are there any tell-tell signs that it could be one or the other? Thanks in advance!
Old 02-03-2013 | 02:08 PM
GonzoJag's Avatar
Sorry about that...3.0 with 91k on the clock.
Old 02-03-2013 | 02:44 PM
QuartzSTypeR's Avatar
Get it scanned and see what the codes are. Its probably a battery if there are a ton of fault messages, so get that checked too.
Old 02-03-2013 | 02:59 PM
JagV8's Avatar
Battery is a LOT cheaper and far more likely. Plus, easier to change.
Old 02-03-2013 | 03:44 PM
Jayt2's Avatar
+2 battery...
Old 02-03-2013 | 06:08 PM
JagMaSteR0917's Avatar
A battery would not set car into limp mode. Need to pull codes and let us know. do not replace battery before pulling codes. when you fine out what codes post reply.
Old 02-03-2013 | 06:34 PM
bfsgross's Avatar
To the contrare...A weak battery "can" light up the dash and send her into limp mode.
Old 02-03-2013 | 08:54 PM
Old 02-03-2013 | 09:03 PM
bfsgross's Avatar
My past four years of Jaguar ownership have allowed many unpleasant but learning experiences...a "lit up" dash, aside from an intense solar flare, is almost pathomenotic of a weak battery. A weak battery can still start the engine, so check the battery for a weak cell(s), its terminals, and alternator, etc.
joycesjag's Avatar
Right on with the battery theory.
Old 02-03-2013 | 09:26 PM
Mikey's Avatar
How come nobody suggested the battery?
Old 02-03-2013 | 10:00 PM
joycesjag's Avatar
Beats the hell outta' me Mikey
Old 02-03-2013 | 11:28 PM
bfsgross's Avatar
Screw the battery, check the reactor!
Old 02-04-2013 | 04:16 AM
steveinfrance's Avatar
Just look what a bad battery did to Chernobyl.
bfsgross (02-04-2013)
Old 02-04-2013 | 09:27 AM
Michael Star's Avatar
doh
Old 02-04-2013 | 09:32 AM
bfsgross's Avatar
Lol!
Old 02-04-2013 | 09:46 AM
GonzoJag's Avatar
Thanks for all the replies! I will have my son throw in a new battery and report back if that doesn't work. Happy trails!
Old 02-04-2013 | 07:20 PM
GonzoJag's Avatar
Update: My son installed a new Duralast Premium battery and all the codes disappeared, except for the CEL. Car runs fine. No way for him to get codes until the weekend. Could the battery have caused a CEL that would need to be cleared at the dealer, or could there be more going on here? Appreciate the input.
Old 02-04-2013 | 08:48 PM
The codes would've gone away while the battery was disconnected. There is still a malfunction stored if the CEL is on. Get it scanned.
Old 02-04-2013 | 10:17 PM
bfsgross's Avatar
Quartz could be correct, but bet a few engine on/off cycles will likely clear the old low batt. fault that initiated the CEL.
Quick Reply: Limp Mode and Dash lit up like a Xmas Tree!
