Limp mode resolution short lived ...
Hi All, some may remember I wanted to report a positive repair I received from Jaguar dealer. Well that was short lived as my limp mode gremlins have appeared again to my disappointment. 2 mechanics and a jag dealer later and I have a limp mode problem. Its pointing to an ABS/PCM comms problem. Jag said the repaired a wiring problem in the harness. However this has come back to haunt me. Oh well, maybe it was a bad idea to buy a jag. Looks like a have a lemon on my hands.
Limp mode ...
Yes I have the incorrect wheels. Trying desperately to source correct ones. Any help greatly appreciated. I am based in SW London...
Spoke to chap last night who has many years experience with Jags and he said Limp mode very like to be a Throttle problem. I explained I have recently had a NEW JAG TPS installed and he thinks Pedal is sending wrong signals to the unit. Which might explain why I get the Idle jumping from a calm 500rpm to near 1000rpm. Then very likely LIMP MODE!! And errors.
The chap is an idiot.
The S Type will NOT tolerate different diameter tires or a change in rear end ratios without going into limp home mode. It is suppose to do that.
Until you get the non-stock tires and rims fixed I would not do anything.
Any chance you bought the car this way? Maybe the other owner never could figure out that tire/rim problem?
Received 2,265 Likes
Still trying like crazy to source 245/40/18 wheels. (Same as front). Looks like the bright spark before me fancied a set of XK Alloys without knowing whether the car would tolerate them or not... If it turns out to be the wheels which are the start and end of my LIMP MODE problems, I swear I will eat my hat! :-) As I have had a lot of grief up to this point with 2 mechanics and a Jag dealer!
aholbro1
08-05-2021 05:02 AM
