Location of BCM module in S-Type R (RHD)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi all,
My car suffers from battery drain. Had electrician investigate it and he is 95% sure it's BCM. Tested all modules, even removed Satnav and after disconnecting BCM the drain dropped to normal values.
Now, I would like to check the numbers on my BCM and try my luck with eBay before heading to the *******. The only problem is I can't find where the bugger is located. Not sure if LHD and RHD cars are different in this respect, but any help would be greatly appreciated.
