Locked my keys in my s type r boot with battery disconnected
Hi guys
I've locked my keys for my 3 cars, Jag, Maserati and audi s8! In my STRs boot, well at least I think that's what I've done cos I've lost them and that's the last time I had the with me when I ran the car for a while and then I have a habit of disconnecting the batteries of my cars when I'm not using them so they dont keep draining!
Basically I would press the button on the remote to lock all the doors with the boot (trunk) open then disconnect the negative terminal off the battery and close the boot and the only thing I can think is I might of left the keys in there as they are nowhere my house!
A guy can come out to pick the lock for around £120 however I'm not sure they are in there otherwise I would gladly pay that but imagine handing over £120 and he comes and opens the boot and they ain't In there then 2 seconds later I will have no option but to slam it closed again lol.
Does anyone have any idea of a way to open it for example if I get power through the starter motor would that give power to the boot release button so I could open a gap on the door and use a rider something to press it to open? I allready wasted a whole day opening a gap in the door and hooking the door handle and button from the inside and it wont open the door as I would imagine it's dead locked?
Any ideas would be Greatly appreciated, I also opened a gap on the side of the boot using one of those pump up gadgets and we put a small usb camera in the boot but cos theres a lot of things in there couldnt see the keys!!
The following 2 users liked this post by clubairth1:
Harry24k (11-08-2021),
motorcarman (11-08-2021)
You guys are Brillaint, Thanks soo much, soo helpful, not one but three different ideas all of which would work im sure, ive ordered the lock pick device but also contacted a jag dealer to see if they can send me my key code cos i found a guy on ebay who cuts a key for £9.75 with either the key code or a pic of the actual key!
Ill try the lock pick thing which also reads the code and if i can get that to work then ill be good if not then ill try the other options you guys have mentioned and will defo get a spare cut!
Im just begging that the keys are in the boot or im back to square one!!
Thanks again guys Much appreciated.
6 cut tibbe pick. everybody and their grandma has the tool it's great for breaking into transits and stuff like that. zero effort required
https://www.amazon.co.uk/Loboo-Idea-...T%2CB0751G5NJN
Finally got in
Ok I finally managed to use the tibbe lock pick on the drivers door and got in!! However for whatever reason the boot lock wont budge, I've tried everything with the same lock pic its obviously a different type of lock even though I know my key used to open it so very strange!
I've given up trying to open the boot with the lockpick it's just not happening so i tried putting power through the cigarette lighter to pop the boot but this won't do anything, I've used this method on other cars like my Audi before and its allways worked but maybe the fuse for the lighter is blown and from what I've seen in the manual its located in the boot?
I'm running out of options now because I know there meant to be a jump start point under the wheel arch of the car but I think the wheel needs to be taken off and oh yeah the locking wheel nut for the alloy is in the
boot!!
The other option was to get a main dealer to give me the key code and get a key cut however because I have traders insurance my logbook is not on my name so they wont do it and said it has to be the same name and address that's on my drivers license so yet another issue there because it takes around 4 weeks to get the new logbook through!
Is there any other way I can get power to pop the boot open, I noticed that all the doors seem to be dead locked as they wont open from the inside so I only have the drivers open.
also to mention again that one of the battery terminals is disconnected off the car when I closed the boot so if that's the case would putting power through one of these ways still work?
Thanks for any advice in advanced
boot!!
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Look at the alternator or starter motor, whichever is easier to access. On the starter, you will see two large red cables connected to one terminal. On the alternator, you will see a large red cable by itself, usually under a rubber cover. Connect battery power to either of these locations and you should have power available to the rest of the car, as if the battery was still connected.
If the trunk release button still doesn't work, check the valet switch in the glove box. If inadvertently depressed (very common), the trunk release button is inhibited.
If still no joy, there may be some points in the front power distribution panel (under the hood) where you could apply power.
Almost forgot: After reapplying power, you may inadvertently set off the alarm by opening a door or the trunk. Not something to attempt late at night in a residential neighborhood…
Your car may also have a secondary alarm fitted, with its own internal power source. Removing primary power may not silence it. Don’t have time to find it right now, but I think details are in the how-to section.
Received 2,677 Likes
Once you've solved your key situation(s), use a battery maintainer instead of disconnecting the battery leads. Each time the battery leads are disconnected, the emission monitors need to be reset prior to MoT.
Not disconnecting the battery also allows for quicker use of each vehicle while avoiding the possibility of creating another electrical fault.
You are absolutely right on...I ground the tip of a valet to fit the trunk because i sometimes use it instead of the flip key when i fish in case it gets wet....i never use it as a valet because i never go any where high class enough to have valet service that is the only choice
https://www.jaguarforums.com/forum/s...02-how-189612/
Same basic thing on an XK8:
https://www.jaguarforums.com/forum/x...ounder-149781/
Not sure exactly what triggers this secondary alarm. I think it's only active if the main battery has been disconnected, which kills the primary alarm system, but don't quote me on that. Most likely the original internal batteries have failed a long time ago, so you may be fine as is.
Boot opened, keys found, Hallelujah!!
Finally this evening managed to get to the alternator as advised by you guys and put a small 4amp car battery charger to it and that was enough to pop the boot, no alarm went off so happy days!!
Thanks again guys for all the ideas and advice, I can finally get to drive the str again!!!
The following 4 users liked this post by Harry24k:
rashaw
05-08-2012 07:37 PM
